Originally Posted by
kzukNA1
The pulley from one of the member here. The balancer split off from the pulley. You don't want to see this on your NSX....
I was looking for the large bolt that kept that one together until you could replace it
It would appear to be another of those preventitive changes worth doing for peace of mind ....
The filter goes under the plastic panel below the wiper arm under the bonnet.
If you are going to carry out this process, it would be best to get hold of some of the spare plastic clips holding the rubber weatherstrip under the bonnet as it is so easy to break them after long years.
Hi Kaz,
As always, thank you for the detailed info.
What is the process for removing the plastic panel please? Is it just the wiper arms and these clips to release it? Is there anything else that needs removal to access this filter and unit for cleaning?
Thank you
Paul
