Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Thread: Hid kit
  1. #21
    The parts are still with me and I was planning to sell them, just haven't realized it yet.
    You should start a bidding auction on this Heineken, I'm good on those and would definitely be interested in bidding for these.
  2. #22
    Might be worth trying .. is there a preferred way to do that or should I just open up the Bazaar here ?
  3. #23
    In that case I'll kick off the bidding with a healthy £200!!!
  4. #24
    OK , let's start with some data from the JDM parts list:
    Code:
    2x 33101-SL0-305   円 145,328 Headlight unit
    2x 33102-SL0-J02   円 105,774 Igniter
    2x 76101-SL0-A02   円  80,576 Retraction mechanism
    2x 76150-SL0-A02   円  77,352 Retraction motor
    1x 76120-SL0-A00ZZ 円  30,033 Lid (headlight cover, one is broken)
    1x 33108-SL0-003   円  99,328 Inverter unit (HID) (only one needed)
                       円 538,391 ~ 3.610,45 GBP
    Above prices are for brand new parts but could .. maybe .. eventually .. serve as a (very) rough indication .. towards .. used parts ..
  5. #25
    Code:
    Crikey!!!!
    Gordon Murray knows.
    Rowan Atkinson knows.
    It's the Honda NSX."
    (J. Clarkson)
    Hooooly cow.
    Super cool conversion, but with a price tag to match!
    Do you know if the harnesses are plug and play?
  7. #27
    Jeeps.... at that price..I’ll build my own....
    £ 201 ��
  8. #28
    Aug 2009
    I did warn you that they weren't cheap! The bulbs are a pretty price too.
    The inverter unit is much cheaper (half the price above) from JP-carparts.com
    The retraction mechanism & motor are similar if not the same as on the non-hid lights, so maybe you can get away with just the igniter, 2 inverters and the 2 HID bulbs.
  9. #29
    The Honda HIDs are notoriously expensive and the harness is unfortunately not plug and play, especially as the inverters are located near the firewall on the passenger side so extra routing is necessary.
    The technical design is also a bit special: The inverters are without the ignitor coil. That one is located near the bulbs.
    As the lights do not have any e-marks they are probably illegal in GB (although I'm not sure).
    If someone would want to install OEM HIDs he would need the Headlight Unit, Igniter and Inverter. The remaining parts should be compatible.
    I'm kind of sorry for spoiling the fun but even the regular Halogen headlight unit is at around 90,000 円 already so it's the usual Honda OEM price madness..
    Me personally, I'm would consider the OEM setup only for the die hard "full original" guys due to price and complexity.
    There are plenty of kits and NSX assembly instructions available online for a retrofit, obviously much cheaper and easier to install than the OEM setup
  10. #30
    Indeed - even a high quality kit with decent bulbs (what else..?) is not that expensive and is plug & play.
