Results 1 to 10 of 16
Thread: Red facelift being 'detailed'
  1. Default Red facelift being 'detailed'
    Is this fine example (well, after the detail) anyone's NSX on here?
    http://www.youtube.com/watch?v=sHh6H...layer_embedded
    '02 Honda NSX [Garage Queen]
    '17 Huracan Performante [Weekend Car]
    '19 Porsche Macan [Daily]
    Who polished it fo rthe past 7k miles .... Torvil & Dean?
    Look out for it at top dollar on PH soon
    Nice to see it being looking like a mint example that it is at the end of Paul's hard work ....
    So who managed to read the tax disc then??
    Are we sure they didn't go over the car with some 1200 grit first, just to make an impressive before and after scenario?
    m666 edd Guest
    So is this just after a session of detailing i.e temporary or is it paint correction where the lacquer is sanded down?
    Most paint looks like this once you've taken all the 'autoglym resin polish' off. Strip lights show up every little blemish, but modern polishes/waxes usually cover up the worst of it. I guess the dilemma is how often do you properly correct the paint. If you use the car regularly, it's going to pick up chips and scratches on a daily basis. Makes you wonder where they all come from. I have a love hate relationship with cleaning NSXs. Whatever people say, they're bastards to clean properly. The 997 I owned was a gift compared, partly because the paint was much harder.
    James.
    AFAIK all of Miracles work is based on machine polishing of the paint work, not the wet sanding process ...
    If the car is going up for sale? A 4K miles NA02+ is going to fetch some serious
    dough!
    1999 3.2 Manual 6 Spd Coupe
    Honda's Finest Hour
    Quote Originally Posted by Papalazarou View Post
    ........ The 997 I owned was a gift compared, partly because the paint was much harder.
    James.
    Is this a common thing amongst German cars? My daily C Class is far easier to keep on its toes compared to the CRV. Both respond well to cleaning/polishing, but the C Class retains its lustre for much longer.
    Maybe I should leave the wrap on S2 and continue not to worry ??
    regards, Paul
  9. Default
    regards, Paul
    I think the colour's got a lot to do with it. In my experience Greys, silver and white seem to resist scratches more. Red, blue and black, not so good. I concede that perception is partly based on the how colours look under certain lights.
    I remember being quite impressed with IOP.
    James.
    It does look unbelievably bad for a 7K mile old car!
    Regardless of whether you machine "polish" or wet sand you're removing the high spots of the lacquer to create a smooth surface. The skill is to remove the absolute minimum to leave a perfectly smooth finish. Of course you can only do it so many times before you run out of lacquer
    The alternative is to fill the low spots with a optically clear material, a "wax", then polish the surface to a "mile deep shine" which most of us do regularly.
    Washing carefully with good technique and products before applying a decent "wax" regularly will stop the scratches appearing in the first place
    Is the lacquer used over different colours actually different or is it just that certain colours underneath highlight the imperfections in the lacquer above leading to the perception of more scratches as you suggest? I think that flat, non metallic, finishes rather than particular colours per se usually look like they pick up scratches more easily.
    As you should be
    Mark
