Page 53 of 58 FirstFirst ... 3435152535455 ... LastLast
Results 521 to 530 of 580
  1. #521
    As seen on other NSX, the camber adjuster bolt was already showing the sign of corrosion. It was not seized to the bush collar yet which was very good news. It will be cleaned and then thin coat of silicone grease will be applied at the time of reassembly.
    On old NSX, the bolt holding the rear toe control arm to the rear cross member can cause lots of trouble due to corrosion. If you can’t loosen the bolt applying just above the specified torque, it is best to disconnect the arm at the knuckle side.
    In the past, I saw lots of cowboy repair works on this area and on one NSX, I decided to replace the rear cross member for the owner as I didn’t feel the previous work was safe.
    On this NSX, it came off with ease and standard procedure was followed.
ID:	8034 Click image for larger version.
ID:	8035 Click image for larger version.
    Driveshaft came off and waiting to be cleaned before painting.
    More to follow.
    There is no point in start removing parts for TB service if I can’t remove this bolt.
    I guess Honda did it on purpose, that only people how are able to loosen that bolt should work on the TB.
  3. #523
    Preparation for the compression check.
ID:	8037 Click image for larger version.
    The battery was charged to full capacity overnight but before carrying out the test, the engine will be started and warmed up a little any way.
    This is getting quite common on UK based NSX. Lots of leaves inside the engine bay especially around the Intake manifold area.
ID:	8039 Click image for larger version.
    Disabled the INJ and kept TH at WOT. INJ will be disabled while cranking at WOT but it is best to disconnect the connector to prevent the initial trigger of INJ.
    Looking at the state of the TH butterfly, it seemed that someone cleaned it in the past. Not much oil mist from the blowby gas was observed.
    The owner told me that the spark plugs were replaced not long time ago. As they are well below the recommended service mileage and there was no corrosion at the insulator area, these will be re-used. No issues were found and all six looked to be burning very well.
  4. #524
ID:	8042 Click image for larger version.
ID:	8043 Click image for larger version.
    The IGN Coils. As seen on many NSX, the coils at the rear bank were more or less corroded at their metal core.
    Especially, the IGN Coil at #1 Cyl was heavily corroded. While there was no misfire reported from the owner, it is recommend to replace at least #1 CYL IGN Coil as it already expanded and sooner or later, it will cause some problem, possibly at the most inconvenient timing.
    Good IGN coil will look like this.
    Hope the owner can get hold of the new IGN Coil some point in the near future from US.
    Compression test showed standard figure for C30A engine.
    The deviation between the cyl was at normal level and it should be minimised once the valve clearance is adjusted carefully.
    #6 cyl showed lower figure than others but still well within the window so quite healthy engine.
    #1: **2psi, #2: **0psi, #3: **1psi, #4: **8psi, #5:**0psi, #6: **5psi
    From here, we just need to keep removing the parts while draining the coolant and try to remove some of the coolant hoses while they are still warm.
ID:	8045 Click image for larger version.
    New and old header tank.
    Draining the coolant from rear engine block using long tube to prevent coolant touching the exhaust.
  5. #525
    As we are going to replace the coolant hoses and engine oil filter, it is best to completely take off the oil cooler from the car.
ID:	8047 Click image for larger version.
    So, first, drain the engine oil from the oil filter and then remove two coolant hoses.
    After disconnecting the cable for one of the Oil pres sensor, the Oil cooler can be removed from the car.
    The area is now quite empty as the driveshaft and oil cooler were removed.
    Removal of parts countinues…..
    Nothing special here. Just keep removing the parts…
    After the compression check, I don’t need the battery so just disconnected it. It will also erase any ECL that I may have triggered during the compression check depending on the spec of NSX.
    The battery conditioner is connected throughout the service to keep the battery healthy.
ID:	8051 Click image for larger version.
    ACG removed, checked the bearing and didn’t feel any rattle or noise which was good.
    A/C idle pulley removed and again, no noise or rattle from the bearing so it will be re-used.
    While the car is in the air, just removed most of the bolts at the TB cover, oil level gauge pipe, brackets, crank pulley, etc before loweing the car.
    By the time when I am about to replace the WP, I would like to be in a position to carry out the leak check on cooling system using all the new hoses, tank, O-rings, gaskets, etc so replacing all the parts on the cooling system is the highest priority at this stage.
ID:	8053 Click image for larger version.
ID:	8054 Click image for larger version.
    Thermostat removed.
    Part of the black molding started to deteriorate and it was the old original design so good to replace it this time with the latest one.
    Nothing new and as seen on other NSX, some of the coolant pipes were corroded.
    They will be smoothed out and all of the hose connection points will be applied with rubber grease during the installation of the new hoses and it will add extra protection against future corrosion.
    You won’t notice this corrosion until you remove the hose so another important reason to carry out cooling system refresh at a certain interval.
  7. #527
ID:	8057 Click image for larger version.
ID:	8056 Click image for larger version.
    All the hoses from the engine bay, under the centre floor and the front compartment under the bonnet.
    Addition to these, two hoses at the Oil cooler were already removed and there was another one at the header tank overflow port.
    So, total of 23 hoses for this NA1 RHD MT non-DBW model.
    Time to install the new hoses.
    More to follow.
ID:	8063 Click image for larger version.
ID:	8064Click image for larger version.
    New metal washers and O-rings for the Centre floor drain bolts and radiator drain/bleeder plugs.
    Drain bolts at the centre floor pipes torqued to the spec.
    Centre floor hoses installed and double checked.
  9. #529
ID:	8067 Click image for larger version.
ID:	8068 Click image for larger version.
    Front section done. Going to keep the water valve cable disconnected until finishing the bleeding of the cooling system.
ID:	8070 Click image for larger version.
    Re-surfaced the thermostat housing and the cover.
  10. #530
ID:	8074 Click image for larger version.
ID:	8072 Click image for larger version.
    New thermostat installed.
    Corroded pipes reconditioned.
    Engine Bay hoses and the new header tank installed.
    Two hoses at the oil cooler will be installed temporary just before performing the cooling system leak check.
    So, almost finsihed with the cooling system refresh and moving onto the rest of TB service work.
    More to follow.
