Since you can't buy ABS Modulator 57110-SL0-Z03 (as well as -N21). I decided to do something about it. The most similar is ABS modulator for S2000 - at least in appearance. (laughter) Information from the market says that in the past Mita sold such a set, however it did not work with Traction Control). As we know, the output signals were missing. "after a long search for these signals (laughter) - I found them.
A big thank you to Britlude, smaller to Kaaz.
I simulated two sine signals with a frequency of 50Hz and 100Hz. Corresponding to one of the front and rear wheels. The modulator converted them into square signals and sent them to the Traction Control
