Results 1 to 9 of 9
Thread: Air-conditioning retrofit on early cars
    Default Air-conditioning retrofit on early cars
    Ok, so I’ve read most of the threads on the forum regarding owners cars still running on the dregs of R12 but wanting/needing to update/upgrade.
    My question is!
    What is the definitive advice for this issue? And what is actually needed? Even better if you’ve actually done it!
    Any help appreciated,
    Cheers.
    I am Godzilla, you are Japan!
    I've upgraded to run R134 gas, which meant changing the compressor, it's mounting bracket & I needed a new pulley. You can read the conversion here, last coupe of pages......
    http://www.nsxcb.co.uk/showthread.ph...assis-Re-fresh
    r-134a-refrigerant-ac-systemb92-027 copy.pdfr-134a-refrigerant-ac-systemb92-027 copy.pdf
    Acura"s service bulletin dealing with the change and differences between the two gases.
    Duncan
    Attached Files Attached Files
    Thanks guys. I knew it wouldn’t be simple!
    I still manage to get the system maintained with R24 which is similar to R12 but more enviromentally friendly. The cost of the recharge is higher but on balance it works well and is cools better than the R134 system.
    Mike
    Quote Originally Posted by sorepaws View Post
    Thanks Mike,
    Just need to find a stockist closer to home.
    Cheers.
    There is also a mix of Propane and Isobutane (available from Poland) which is cheap and compatible with all oils and cools well - it's flammable, though.
    Does this mean you are no longer resting between cars James?!
    Gordon Murray knows.
    Rowan Atkinson knows.
    It's the Honda NSX."
    (J. Clarkson)
    Quote Originally Posted by WhyOne? View Post
    I might have a winter project. �� Nothing big. Just a bit of general maintenance.
    Cheers.
