Results 1 to 10 of 18
Thread: UK Panel Clips Supplier
    Default UK Panel Clips Supplier
    Hi Guys
    Has anyone found a UK supplier (other than Honda UK) for the 3 small plastic panel clips that hold the rear bauklhead upper panel trim in place?
    Honda part No. 91560-SL4-003 or possibly 91560-SM4-003 (1991 NA1)
    Ta Gary
    If if you search those part numbers on eBay you should get a few options.
    Quote Originally Posted by Gary View Post
    Hi Guys
    Ta Gary
    SM4-003 (superseded to SL4-003) has round end tip and because of the material used and the design, unless you perfectly align the end tip to the hole on the firewall, you will break the clip when pressing on it.
    Instead, I normally use the SL0-T00 introduced on the later models.
    It has sharp pin point end so that it's much easier to aim/feel for the hole at the firewall.
    Because of it's shape/material, it's hard to break it.
    Although it's for later model, I have no problem using it on earlier models as well.
    Not cheap from HUK though and I don't know whether there is an aftermarket one available or not in this design.
    By now, I think clips from recent Honda models should do the job so just browse through some of the aftermarket clip manufactures website and try something similar.
    https://www.ebay.co.uk/itm/10x-Pilla...IAAOSw8w1X-19G
    Are these the same or usable in the same context?
    There is a compatibility checker on the ebay site for our car "This item does not fit Honda NSX 1991 NA [1990-2005] Coupe Coupe 3.0 24V VTEC 2977ccm 2"
    Mike
    Hi Guys
    Ta Gary
    Two candidates purchased (along with broken OEM parts).
    Fitting test later today.
Name:	NSX Upper Rear Panel Trim Clips.jpg
    They do look almost identical. Let us know how they fit and if so, details please.
    I'm sure some will claim the red ones add to your top speed.....
    If you had green ones they'd automatically fit.
