Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 141
  1. #51
    What kind of airfilter has been used in the past?
  2. #52
    Feb 2014
    Madrid,SPAIN
    Hi Goldnsx, now and in the last 30.000 kms the original Oem filter, in the previous 90,000 km I do not know...
    these are more the remains of oil and residue in the admission bucket and admission butterflies
    also, very dirty one of the filters
    when I started to disassemble the injectors, and first of all, just moving them, started to lose gasoline by the top of the injectors, the rubbers are damaged and in poor condition
    I am already cleaning everything, changing new joints and I have taken to clean the injectors
    I will keep you informed
    NSX 93 conversion NSX-R 02
  3. #53
    Ups, lucky you, the o-rings of the fuel injectors look to be the first ones. I change mine every 10 years or so. High recommended for anybody out there.
  4. #54
    Those metal bits don’t look to good.
    What is that you’ve picked up???
  5. #55
    There's a lot more coking up in your inlet than mine. I think in this case, a wise decision to strip the parts down for a major overhaul. I'd get your injectors professionally checked out, if they're in that condition. Hopefully I'll get my cam covers back for the easter break and with a bit of luck, even get the car back up and running.
  6. #56
    Feb 2014
    Madrid,SPAIN
    Hi Pride, there are no metal parts, it's just a lot of dirt and deposits of oil and oil clumps.
    I am again assembling everything, it will be ready in a couple of days, with all the new gaskets
    the injectors have cleaned them inside and also outside with ultrasound, the rust has disappeared, it seems that two of them did not work well
    When everything is ready and I will drive again, I will tell you if there has been improvement
    Remi
  7. #57
    Rear bank coil packs not so good, new ones ordered.
    Pipes and brackets re painted. Almost completed this years winter re-fresh, wish someone would tell the weather it's no longer winter !!
  8. #58
    Hi Wix,
    Reminds of one of my past winter refresh projects ... I took all the front compartment brackets out, prepared them and then had them all powder coated in an aluminuim finish ... very rewarding work when its all done ... oh, and keep the faith as the weather is bound to break by June
    regards, Paul
  9. #59
    Hi Wix,
    regards, Paul
    Hi Paul,
    Yes, that's another one of the jobs on the list, although I did buy two new radiator top mounts amongst all the parts I needed to do the engine re-fresh and I had to remove the radiator to replace the top drain tap, that had snapped off last year.
  10. #60
    Cam covers & Plenum cover back from having a nice new coat of crackle finish applied.
    Really pleased with the finish. Had them done here,
    http://www.redditchshotblasting.co.uk/contact/
    only need the new coil packs to arrive and the car is ready to have the last few things put back together and it'll be back on the road, hopefully in a week or two.
