Is your engine showing any strange symptoms to justify doing this overhaul??
I've done nearly 240,000km and as far as I can tell, touch wood, it starts, runs and performs as well as it's always done. My motto is "if it ain't broke don't fix it" just enjoy driving it.
I think unless like Wix you needed to remove all these components in order to access, in his case the knock sensor, surely it might be wiser to just leave best alone, unless of course you've either got plenty of time on your hands and/or you just love getting stuck into sympathetically and mechanically maintaining your car as a hobby.
Having said all that your car car does look exceptionally stunning so you probably do love doing that. 😁
I agree with Pride, "if it ain't broke, don't fix it". I wouldn't have stripped this all down just to clean it and TBH, a lot of the original parts were in excellent condition, for a 27 year old car. The only things that probably did need replacing were the coolant hoses that weren't the best and the report back on the fuel injectors said they were uneven in their spray pattern but they have now been serviced and cleaned, so this alone should make the car feel and drive better.
On the plus side, I do now have some more spare parts.
Hi, I want to clean all the admission,I disassembled parts and I found a lot of oil and a lot of dirt, and I have time and the spare parts to do it.
Sometimes it does not start well, something is dirty, as lazy. I will going also check the injectors to check them.
I will tell you
Remi
NSX 93 conversion NSX-R 02
Do you need all those washers when replacing the filter, or did you get extra just in case?
Update of some info I should've posted on a previous post, as it may be useful for others. I had my fuel injectors serviced and cleaned at Carwood, I used the Coventry branch, as it's local to me. They send to another branch to actually do the job and only generally a few days turn around.
https://www.carwood.co.uk
Hello everyone,
following the post of the friend Wix and for not opening a new one and as I commented in this same post, in the end I decided to clean all the admission of my NSX.
My car has 25 years old, I do not know exactly how the previous owner took care of him, but he knew that inside he was very dirty, and indeed he was very dirty.
he main access had a lot of accumulated fat and dirt, and the injectors, very dirty and rusty they needed a cleaning urgently of all parts
there was so much hollin, that some holes were plugged
I will continue later with more publications and photos, I can not continue now
