Page 1 of 58 1231151 ... LastLast
Results 1 to 10 of 580
    Default NSX Health Check Service
    Hi, all.
    Addition to my NSX Climate Control Unit (CCU) service, I have been offering the NSX Health Check Service for some of the members here.
    As I received similar questions on this, I would like to share some of the information of the service and the maintenance works carried out based on the result of this.
    [Edit: It will take minimum of 4Hrs plus another 1Hr for the report.
    Due to the time required and to be fair with the owners who are taking the further service based on the health check report, the new price is GBP250 as of May/2012 and it includes GBP100 deposit towards the future major services.
    The depoist is valid for a limited time decided by myself and as it is recommended to take Health Check service once a year, the time limit will be much shorter than that.
    The criteria of 'major service' to be decided by myself.
    The depoist of GBP100 won't be refunded to the owner if one couldn't take the major service within the time limit unless separate agreement has been made with me.]
    As I can only carry out this during my spare time at this stage, it will be private/friend basis.
    I will inspect your NSX for about 150 check points from top to bottom and front to rear. During the health check, I’ll ask several questions such as when the last time this part was serviced so it would be nice if you can bring your service record or study them prior to the health check.
    After this, I’ll summarise the recommended future service works with three different priorities so that you can discuss with your mechanic or myself to schedule the service timing and also spread the cost. It is recommended to carry out this kind of Health check every 6 months regardless of the mileage since the last health check.
    As a personal opinion, anyone with NSX workshop manual can carry out the service work. Also, anyone with the parts list can place the order for you.
    However, the service result would be different depending on the knowledge, skill, experience and so on. On top of these, there are several things that can only be detected by the sense/feeling which is not on the workshop manual.
    You could be ordering a part without knowing the fact that it could be repaired rather than replacing or it could be upgraded with small extra cost.
    Addition to these, knowing the car from the development stage, understanding the specific design reason of each parts and experience in the motor racing will make different level of service.
    Some of the members decided to go ahead with the Health check service and even went further to leave the car at my place or placed orders for the parts.
    Followings are some of the works that I carried out recently.
    New Front Brake Disks and Refurbished Front Brake Calliper with new pistons
ID:	5345 Click image for larger version.
    ABS service including flushing the four solenoids
ID:	5347 Click image for larger version.
    Last edited by Kaz-kzukNA1; 19-05-2012 at 10:38 AM. Reason: Price and required time updated as in [Edit:] section.
    Vacuum test and fill of coolant with new header tank, thermostat and cap
ID:	5350 Click image for larger version.
ID:	5351 Click image for larger version.
    The coolant hose will be forced to collapse during vacuum test
    Oil filter filled with Oil
    Air mix motor repair and Door linkage repair
ID:	5355 Click image for larger version.
    Door panel internal weather sheet repair
ID:	5357 Click image for larger version.
    Antenna mast service
    Nice new weatherstrip and Washed the car and dressed the tyre
ID:	5360 Click image for larger version.
    Hope you enjoyed.
    Kaz can you carry out services such as the harmonic balancer swap and a clutch change?
    Ary
    Kaz,
    Where are you based in Bucks? I'm also in Bucks.
    There is quite a lot of work to be carried out on my car including air con, new front knuckles (worn ball joints!), replacement ABS modulator etc . . . not to mention window fix kit and other smaller items.
    I had been planning for most of this work to be carried out at a local garage . . . well at least the larger work. However things like the Antennae still do not work properly so I would be very interested in your "check up".
    Please PM me.
    Regards
    Nathan
    '92 Red/Black
    RS*R Exhaust, DC Headers, SuperDuper LeMans AirScooper, Dali Stealth OEM Airbox Mod: Fujita Filter, OEM 2002+ GOLD calipers + 2 piece race rotors . . . take a breath . . . and finally Nitron one way adjustable suspension!
    amo Guest
    also id luv to pop in and have a chat with you
    pm me ur address im in chalfont next week wed and thur
    thx amo
    Ary
    Hi, Ary.
    Yes, I can carry out these works and if your clutch is not slipping yet, it would be best if you can first carry out the health check and then discuss the future service work with me or with your mechanic. Quite often, it is best to replace several parts around shift folk area when you are replacing the clutch but not many people are doing this.
    At the moment, I'm preparing to drop the engine and gbox from my car (5MT) and from another car (AT) in order to take lots of photos. Then, I would like to setup and offer several packaged maintenance menu. The aim is to be able to offer the refresh maintenance service for our NSX.
    I just need more time and space in order to carry out these services. Hope to post something on here in the near future.
    Hi, Nathan and amo.
    I'll send PM to you after this.
    Hi Kaz,
    I'd love to sign up for your service.
    I had already had the air con / CCU and Bose speakers on my list of repairs needed and was going to approach you about that work, so if you're able to fit me in for that, I'd be happy to add the service check too.
    Let me know the kind of timescales you're thinking of.
    I'm based in Windsor - where in Bucks are you?
    PM me if you have a sec.
    Cheers.
    Parvin
    1992 JDM NSX Auto, Marga Hills Wide-Arch Body Kit, Taitec JGTC Centre-Exit Exhaust & Diffuser - 'The Dream'
    2006 Lexus RX400h - 'The Work Horse'
    Quote Originally Posted by Auto Spirit View Post
    Hi Kaz,
    I'd love to sign up for your service.......
    Cheers.
    Parvin
    Hi, Parvin. Thank you for showing interest to my service. I'll send PM after this.
