Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Aftermarket Steering wheel/ boss
    Sparco does one that fits (I think it's the Civic one) and you need a 12mm spacer.
    If you go for the Taitec boss you keep the cable reel and can wire in the cruise etc very easily. It's one of the more expensive options at around £200 delivered.
    ARGH I'm getting information overload now!! I don't mind the price if it makes life easier.
    I'll check it out.
    Jun 2003
    Chexbres, Switzerland
    That is not entirely correct!! MOMO did make the HUB for the NSX and did sell it branded as their own. It was MOMO P/N 4916 and at the time when they sold it, it was only about £50.00!!
    I was speaking in the present tense. I know of the Momo 4916 but that's history.
    I binned the cruise control on mine but being a JDM car it didn't work at speeds above 70mph (112kph) anyway effectively making it useless for motorway (continental) cruising.
    Mark
    Mark
    yeah fair one, but seeing as it is one of the few things that works on my car ( I actually inadvertantly fixed it while trying to fix my headlights......long story!)
    I'd like to keep it.
  5. #15
    Default MOMO and OEM Type-R, S Hub
    Hi,a ll.
    Just for your reference.
    Most of the aftermarket steering wheel and hub uses 6 bolts to attach the wheel to the hub. Thus, there are normally only 6 fixing holes on the steering wheel and the hub including MOMO 4916.
    The OEM Type-R, S hub is based on MOMO (there is the 'MOMO' logo engraved) but being modified with 3 extra fixing holes. OEM steering wheel uses 9 bolts to fix itself to the hub.
    The benefit of using OEM or MOMO hub is that they have crushable structure in case of huge impact to the wheel under a certain accident....
    Well thanks all, lots of good suggestions and info, plenty food for thought.
    If anyone knows of anywhere in the UK to get the parts, please let me know.
  7. #17
    Sudesh Guest
    Hi,a ll.
    Hi Kaz!
    Have you more details on the 9 bolts and fixing points? I have the OEM NSX-R hub and MOMO Tuner wheel [same as NSX-R] but I didnt notice any difference in the amount of bolts between the NSX-R wheel and others?
    Or is the for other wheels other than MOMO??
  8. #18
    Hi, Sudesh.
    To start with, although you already have this, followings are the photo of the OEM R Hub. As you can see, there are 9 fixing screw holes on it.
ID:	4862 Click image for larger version.
    Engraved 'MOMO' and '4916' logo on it. Based on MOMO #4916 but with extra 3 fixing screw holes.
ID:	4864 Click image for larger version.
    The biggest difference between the OEM Type-R MOMO steering wheel and the aftermarket ones including MOMO is the number of fixing holes. As you can see below, there are 9 holes on the OEM Type-R version.
    There are some differences between NA1 and NA2 Type-R but in general, from outside, you will only see 6 bolts on the steering Ring (no.6). 3 extra fixing bolts will be hidden under this Ring.
    Sudesh Guest
    Kaz,
    Thanks for the info, I noticed the momo logo and numbers on my hub too.
    Always wondered what the extra holes were for but now I see from the pics and your description they are hidden below the ring. My guess the 3 extras are to support the steering wheel while trying to install the horn and steering ring.
