I'll let you know how I get on after watching some YT tutorials.
i can recommend Rustbuster Fe-123
I know you guys want to pimp your old ones, but these are currently £8.00 each on Amayama. That is plus postage which is also £8.00. So yours delivered for £24.00. And they said my maths weren’t gud. Or waz it my inglish?
Anyway, failing that, clean up the original ones then spend weeks looking for the right colour spray paint. Personally, I like OE for these. Whenever I see anything but OE I wince. But then I am full of contradictions.
Cheers.
I am Godzilla, you are Japan!
Hey, Papa L, I hear you. But it just seems to be one of those few jobs I should be able to do myself. So the sense of achievement for me will be disproportionate. I suppose I like the sustainability benefits of refurbing, too.
@britlude - thanks. Will check it out.
A few years back I took all of these brackets to the local powder coating shop and they still look good today ... total cost for over a dozen items was around £40 ...
Did they sand/grit blast as the first part of the process? I'm toying with that for the rear strut bar. Because that's a lot more work than these small plates.
I'll post photos of progress ASAP. After watching a lot of YT tutorials and reading squillions of forum comments, I've taken a simple approach:
0 - brass wire brush to remove loose flakes
1 - citric acid bath overnight
2 - bicarb of soda wash
3 - water wash and dry
4 - degrease
5 - direct to rust paint
