Clock
, 17-07-2012 at 11:28 AM (3865 Views)
I always wanted to test this mod but because it was so simple,
it was just left at the bottom of the list and never had the chance to do it on my NSX.
I think another member here questioned the same thing long time ago.
As I had some spare time today, finally decided to try it.
It is to disable the illumination control at the clock display.
I can’t remember what it was like when my NSX was new but for many years,
when I switched on the small/parking lights, the clock was almost invisible under
the bright condition.
So, pulled out the #3 terminal (I think it was Red/Blk wire) from the connector
behind the clock and insulated it as it would be at the battery voltage whenever
any of the light switches were operated.
Not sure you can notice the difference in the above photo but
while the rest of the illuminations were dimmed,
the brightness of the clock display stayed the same even
when the light switch was operated.
My NSX is JDM so the wire colour could be different from yours but you should be
able to find the correct wire because there are only 4 wires in the connector.
It's the only wire that will get battery voltage whenever you switch on the light
even without the IG key.
Rest of the three wires are the GND (#4: Blk), IG1 (#1: Yel), Backup (#2: Wht/Yel)
Will test it like this for a while during the day and in the night then decide
whether I should go back to the original state or not.
