Results 1 to 10 of 11
Thread: Kaz's not so build thread
    Default Kaz's not so build thread
    Testing how to implement tag and raindrop like structure.
    MOT: Jan/25
    Battery Health: Jan/25
    [Link]
    A/C CCU service:
    Audio Head Unit:
    Emission Test: Keep CAT Hot!
    Gauge Cluster:
    Spark Plug: MX-5 Spark Plug
    Tag headers
    #alternator
    #battery
    #cat
    #ccu
    #driveshaft
    #emission
    #sparkplug
    Find a way to display in Hybrid mode for the specific thread by default.
    Or, format in App friendly structure for future proof.
    Create '#Tag' page.
    Review how it could be displayed in different platform.
    Or, may try creating different structure through Admin control panel through requests from the users.
    Possibly best waiting until the new platform introduced.
    Default Mot
    #MOT MOT
    Earlier this week, passed MOT.
    94 JDM so 31 years old this year.
    Original CATs and already covered 177K miles (284K km).
    Drove for a while in 4th gear at moderate speed to keep the ECU in open loop.
    Then, back to closed loop and straight onto the emission test.
    Easy and never failed.
    Time to start looking for the replacement rear tyres.
    Don’t like Neova AD08RS and not sure UK will ever receive AD09 for the OEM 16/17 wheel.
    Interested in PS5 but when the time comes for the front, it's bit too narrow for my like.
    May try Advan Fleva V701 as several owners had good experience but not sure of the wet balance.
    I always liked the behaviour of the original AD08 and the AD08R in wet condition.
    Probably decide in few months.
    Default Battery Health
    #battery battery
    #topdon topdon
    #batterytester batterytester
    During spring and summer time, A/C is always one of the most discussed topic.
    During the cold period, it’s the battery.
    Last week, started working on the alternator and the gauge cluster but latter part of the week/weekend was just too cold.
    Not a problem for my body as I wear fireproof to keep myself warm.
    However, since I use my bare hand when dealing with delicate tasks, it just made my finger numb as soon as I touched any metal surface.
    So, focused on the electronics component service.
    It was also good opportunity to carry out the health check on my 5.5 years old Yuasa battery.
    It’s actually related to the reason why I ended up servicing the alternator and the gauge cluster mentioned above.
    Mine is YBX5005 and just a lead acid flood battery.
    Installed it in Jul/19.
    Used to replace the battery every 8 years in UK regardless of the battery condition.
    In Japan, due to scorching hot summer, quite low rpm environment and majority of owners using their NSX for short distance journey, many are replacing the battery every few years.
    My personal view is that because of the hot summer in recent years here in UK, it has shortened the battery life.
    Before replacing the battery in 2019, I always went with the Honda OEM one.
    Don’t know who manufactured it.
    I think the last one was made in France???
    After 7 years, it clearly showed the slow cranking speed and while I could have kept using it, replaced it.
    Now using YBX5005.
    This specific battery can be out of stock from time to time on Tayna Battery website.
    Already experienced twice.
    The health check from 2023 and just last weekend.
    The car was parked for 45Hrs, outside temperature went down to -5degC but the car was kept inside the garage so didn’t know the actual air temperature inside the garage at the time of testing.
    As regularly driven, can’t even remember when was the last time I connected the battery conditioner to this battery.
    So, it was charged only through the alternator.
    Can’t do direct comparison as so many conditions were different but when I started the engine, for the first time with this battery, the volt gauge went down close to 9V.
    Still, managed to start the engine no problem but with slower than usual cranking speed.
    This week, much warmer and the voltage stayed just about 10V on every cranking so going to keep using this battery for now.
    Should have many months to go with this battery but for the next one, want to try the EFB type.
    Yuasa has YBX7005 as the EFB but according to Tayna website, it’s discontinued, although Yuasa still displays it as one of their available model.
    Some online shops are showing it as in stock but could be from very old batch.
    Will see when the time comes.
    If not available, I'll try the EFB from Bosch - S4E40.
    Quote Originally Posted by Kaz-kzukNA1 View Post
    #MOT MOT
    Hi Kaz,
    I have always struggled with emissions being close to the limit for MOT.
    Could you please explain further what you mean by the ECU being in open or closed loop and how to achieve this for the best readings on the emissions test please.
    Many thanks
    Olly
    #emission
    #cat
    Nothing special.
    In my view, emission test in UK (NI has its own MOT rule) on pre-Euro Standard make/model is fairly reasonable compared to some part of the world.
    Please note that if you use aftermarket ECU, sport CAT, bypassed the fuel pump resistor, have crack/leak at the exh system, complicated aftermarket exh backbox design would affect the reading.
    There are many research carried out on the chemical used in certain engine oil that could reduce the efficiency of the OEM CAT over time.
    Some of the very early NSX models (91 and some 92) require only the non-CAT test.
    For the later models with BET (Basic Emission Test) mode, it even allows secondary test in case it failed the initial one.
    All the criteria and the procedures can be found in the MOT manual online.
    There are lots of good articles, chemical equations and diagrams on how the CAT works on the web so please take a look.
    Same goes for the HC, CO and NOx amount below (rich) and above (lean) the lambda window with the effect on the CAT efficiency. You’ll find pretty much all the basic you need to know on the web.
    And same for the EFI control.
    There are plenty of articles on how the ECU uses open/close loop control based on OEM narrow band O2 sensor and the reason why it aims for the control window mentioned above.
    The rich/lean condition for acceleration, fuel economy, NOx reduction, chamber temperature, CAT efficiency, etc are all covered.
    I won’t go into detail for IP reason as I don’t even comment in the ECU discussion on Prime or FB group.
    Based on these and how the emission test is carried out (test at the idle rpm always follows the higher rpm band first), you’ll know to keep the CAT hot.
    No need driving aggressively.
    Just keep driving in 4th gear or whatever the gear that you can keep above 2.5K – 3Krpm.
    Doesn’t matter if the rpm drops below that window from time to time.
    I normally drive at least about 15min on dual carriage way in 4th gear at cruising speed and once heading to the MOT station, use higher rpm band than I normally would.
    On arrival, keep the engine running.
    Ask the MOT operator to carry out the emission test first.
    If you have to wait for your turn, keep the engine running (be careful with the new regulation on running engine unnecessarily) and blip the TH from time to time.
    UK has good regulation on fuel quality so unlike the fellow owners in US, we don’t see bad test result at the time of INJ flow rate measurement.
    Used to see fuel sample spectrum analysis.
    Don’t know the spec of your NSX but if your O2 sensors have covered more than 60K – 100K miles, Bosch recommends replacing them (primary/upper/sensor 1/before CAT ones).
    Later model has air assisted INJ and/or secondary air bypass system.
    Even thick tube for the air assist passage, be gentle handling them.
    The metal pipe held at the side of CYL head for the secondary air system could get cracked so worth checking from time to time.
    EGR valve is monitored by the ECU but only for the needle lift and not the actual exh gas amount.
    Although it has main effect on the NOx under cruising condition, it will reduce the oxygen and chamber temperature.
    Seen CEL being triggered on several NSX for fuel mixture error codes and not related to the EGR but the truth was, it was triggeed because of the specific area of the EGR control.
    Cleaning the EGR passage is recommended on high mileage or poor fuel quality area.
    I normally replace both O2 sensor at the time of Eng Refresh as it’s so much easier to access them especially the one at the rear bank.
    For the EGR, when taking off the intake manifold for the VVIS butterfly service, I look at one of the port/pipe and if full of carbon, I would clean the passage on next big service.
    Also, there is one section to be checked for the EGR control but you will first get the CEL not related to the EGR.
    Default Spark Plug - MX-5
    #mx5
    #mx-5
    #sparkplug
    Not really NSX related but something interesting….
    Recently, got misfire on my boss’s MX-5.
    Wanted to move it out of the way so that I can open the garage door and get enough space for removing the door card on the NSX.
    Started the engine and immediately, got misfire.
    Previously, had tiny occasional misfire only when blipped the TH.
    Nothing at idle rpm or even at steady high rpm band.
    No misfire under other conditions so thought it was aged fuel related.
    Didn’t feel like moving the car with the misfire so started removing the spark plugs.
    After removing the #4 cyl one, noticed much corroded metal body compared to all other three.
    The corrosion level was far better than what I saw on other make/models.
    In fact, I saw much worse ones at the rear bank of some of the NSX out there.
    However, when I tried pulling out the plug body from the plug socket, this happened.
    From what I can see inside the insulator, the corrosion started long time ago and the rust managed to chew into the internal wall of the metal body.
    That compressed the insulator and with the vibration, caused hairline crack resulting in flashover and misfire.
    It almost looked as if the insulator was cut through by the sharp knife but impossible as it was under the metal body.
    Quite surprised I only got the misfire all of a sudden and not progressively.
    Even more surprised that such moderate level of corrosion can damage the insulator body.
    Other possibility is the tool hitting the plug at angle but due to the deep and narrow IG cable/plug channel, it’s impossible to insert the plug socket with the extension rod at angle against the plug body.
    So, the only cause is the corrosion/rust but only with such moderate level???
    The red section is where the flashover happened.
    Fortunately, the spark plug (BKR5E-11) on MX-5 is just a standard type and widely used on many application.
    Can be sourced from many places and even stocked locally.
    By the way, don’t see the point in using the Iridium ones or even the latest Ruthenium on NA engine unless heavily modified the engine hardware.
    Some Iridium plugs have much shorter life than the double platinum ones used on our NSX.
    Got the new plugs but the biggest challenge was the weather.
    Freezing cold and ended up replacing them outside under the sleet condition.
    Still, unlike working on the NSX especially at the rear bank, so much space and easy to change the spark plugs without bending the arm or the back.
    Fired up and probably just in my mind but the engine ran so much better than before the misfire happened.
    Really need washing my NSX and the MX-5, get the chainsaw out to prune some of the trees, etc.
    Must visit Japan Embassy to sort out some certificates…..
    So much to do so hope the weather improves in the near future.
    Default Condenser Fan Motor – L side
    More than 2 years ago, the L-side condenser fan motor failed.
    Just didn’t have the time working on my NSX….
    Needs replacing the CL as it’s at the end of its life.
    Gbox overhaul as the bearing is making annoying noise.
    Into 14th year from last Eng Refresh….
    However, the recent FB post from britlude encouraged me take action.
    The motor was not seized and the fuse was not blown.
    The blade still spins freely when accessed from behind.
    Just nothing even with power applied.
    Probably the brush has gone after so many miles/years of a/c usage.
    I always use a/c whenever I drive apart from when the sharp acceleration required.
    One owner kindly sent me his failed fan motor few years ago so that I could study the internal structure and the brush size.
    His motor also failed with the worn out brush.
    As I didn’t have time on this occasion and most likely the same will happen at the R-side soon, decided to simply replace the L-side motor with a new OEM one.
    I have my own policy of not touching the front bumper unless 100% have to.
    I already knew how difficult and time consuming it is to align the bumper/bonnet/wing/headlight cover as a set.
    Replaced the fan motor several times in the past without removing the front bumper but always struggle with the oxidation and rust around the bolts/screws.
    With my NSX, it was the 2 out of 3 screws holding the motor body to the contender fan bracket.
    The JIS screw head was already heavily rusted.
    Had replacement screws so not a big drama but still took some time removing them.
    New motor fitted and it’s now working again.
    Still using the original condenser but at least, my a/c should work much more efficiently than the last few years.
    Default Dressing/Detailing
    #dressing
    #detailing
    #leathertreatment
    #autoglym
    #ko-cho-line
    It's that time of the year – dressing in preparation for the car event.
    Nothing special and just using the Autoglym Vinyl & Rubber Care around the car.
    For the cabin, just massage in the Ko Cho Line Leather Dressing and leave it overnight.
    Wipe off any excess next day.
    May not be suitable for some of the material/colour but for me, worked well for years.
    It's my everyday car but only just once or twice a year application is enough.
    Oct 2010
    Guernsey
    Very nice Kaz
