Page 69 of 78 FirstFirst ... 19596768697071 ... LastLast
Results 681 to 690 of 772
Thread: NSX Refresh
  1. #681
    Sudesh Guest
    Quote Originally Posted by Nick Graves View Post
    Good grief! A part that I never even knew existed; you learn something new every day.
    I'm used to those nasty, asthmatic clutch delay valves in the M/C.
    Hi Nick,
    Yes it's a nice little upgrade but works best with the short NSX-R pedal. I've had this setup installed on my NSX a while now both with standard pedal and NSX-R pedal and obviously works best with the NSX-R pedal [the way Honda intended] as it uses less stroke, so quicker pedal work.
  2. #682
    Sudesh Guest
    NEW NSX-R Clutch pedal installed
    Can be quite awkward to work in there as one bolt in particular is hard to access, but Ive been down this road before was well prepared, just need to be careful and wear gloves as there are some sharp edges on the clutch housing and need to be careful cautious removing the housing out over the clutch master rubber.
    OLD PEDAL
    Cover the interior so not as to damage seats, sills, plastics etc
    disconnect the plug that goes into the clutch switch, release the clutch fork by removing the split pins or R clip depending on year, remove 3 bolts then carefully remove the complete assembly
    Remove the old clutch pedal, one big long bolt and push clutch back to lift out of the spring, you dont need to remove the spring but again just be careful around this area.
  3. #683
    Sudesh Guest
    There is a metal bushing inside the pedal, so take that out
    OLD AND NEW PADALS
    Put the bushing back into the new pedal
    Install new pedal
  4. #684
    Sudesh Guest
    And the pretty much do everything in reverse.
    Clutch stroke is then adjusted to NSX-R spec and bleed system.
  5. #685
    nice one ... looking forward to trying it out, hopefully not take too long to get to grips with it
  6. #686
    Sudesh Guest
    Quote Originally Posted by nobby View Post
    You'll love it, I noticed the difference right away and your pedal feel is nicer, even my brother was looking at your car today and commented on the pedal clutch/pedal feel.
    Have read thru this whole tread over the last days and I must say you do very good work.
    It is very inspiring to see all the great work you have done, have actualy made me change my mind regarding the plans I had for my car. Was planning for a +02 facelift(sideskirt, rear valence and rear lights) but are going to focus on making everything work perfect instead.
    Could you please tell me the partnr for the clutchpedal, just installed a sos sports clutch with damper removal kit this summer and want the pedal to finish it off.
    Thank you for all this great info and keep up the good work!
    KennethSK
    Norway
    93 Honda NSX
  8. Default
    Sudesh... do you know what exactly needs to be customized to install this pedal on a LHD??
  9. #689
    Sudesh Guest
    Quote Originally Posted by UnhuZ View Post
    Hi Nuno,
    I'm sorry I don't.
    I've never been in a LHD model or worked on one, and not likely to see a LHD NSX where Im based, so I don't know if it would fit, or what would be be needed if some kind of modification work had to be done to get the pedal to work on LHD.
    Sorry not much help on this occasion.
  10. #690
    Sudesh Guest
    Quote Originally Posted by Lonestar View Post
    Many thanks for the kind words and taking the time to go through my thread.
    Ill pull get the part number from my NSX file when I get home and let you know.
