Results 1 to 5 of 5
Thread: nsx stereo/diff noises
    Default nsx stereo/diff noises
    I would like to replace the bose/honda system with a normal cd/radio
    head and standard speakers
    has anyone else done this?
    When turning sharply but slowly (in a car park for instance) there is a grinding sound coming from the rear end.this sounds expensive!Has anyone else had this problem and what is it?
  2. Default
    re: stereo options - spend some time reading the threads in this section of NSX Prime - you'll find plenty of different ideas to think about
    Darren Ferneyhough
    http://today.nsedreams.com
    Working with a growing team improving health, wealth & prosperity.
    If you know someone that wants or needs to improve any of these
    areas please connect them with me via my LinkedIn profile above
    Default RE:Diff Noises
    Hi Colin,
    Welcome to the forum. I am no expert on NSX transmission, so there may be some one more qualified to help you than me, but here are a couple of ideas as to what it might be:
    [1] If it is more of a clicking noise, it could be the CV joint on the driveshaft. This is unlikely as this is more often a problem with FWD / 4WD cars, were the CV joint is under more stress when on full lock and transmitting power. As all the load is transmitted though a stright line down the driveshaft (well sort of), this is less likely, but not unheard of.
    [2] If it is more of a grinding noise as you have described, it might be the diff itself. The most likely thing will be that the clutch plates have worn, and are dissenguageing to early. This can be checked by the following easy test (lifted shamelessly from the service manual you can download from NSXprime - http://www.nsxprime.com/FAQ/Referenc...991_svcman.htm - see page 542 or 15-4):
    [A] Lift up the RH RR Wheel
    [B] Block up the other three so that they aren't free to rotate
    [C] Now measure the preset torque (clockwise!) on the hub nut using a guage type torque-wrench. Basicaly this is the torque required to rotate the wheel against the force of the diff. The Assembly standard is 60 - 140 NM, but the service limit is 30NM.
    [D] If the Torque you record is less than the service limit, then you need to replace the clutch plates.
    Of course, there is a third option, which is that you have broken one of the clutch springs in the clutch pack - but I think this should be shown up in the same test, but the diff will be near locked (err - I think!), so you will see a torque of greater than 140NM. Either way, you will have to replace all the plates and springs.
    I hope this helps, and if not, I hope that some one else on the list can sort you out better than I have!
    Good luck, and let us know how you got on.
    Rob
    "A closed mouth gathers no foot"
    Is it only on low speed turns?
    It could be a worn/loose wheelbearing.
    ....also, something that worked for me on another car I had years ago was to change the fluid in the diff for fresh stuff of the correct grade. Unles of course you have changed yours recently.
