Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Valve clearance adjustment tools
    The tools can be easily made; an old tubular box spanner, cut down with a 19mm AF nut braised to it and an equally old screwdriver with a thumb wheel braised to it.
    See attached photo;
    The box spanner was an old imperial one but could have been metric; needs to fit a 10mm AF bolt head, overall length including nut 115mm.
    The screwdriver started life as the shaft from one of those horrible reversible flat/cross point screwdrivers, overall length including thumb wheel 130mm.
Name:	Valve Adjusting spanner & screwdriver.jpg
    Hi, gcon45.
    If you don’t have the correct tool or huge impact gun, you will struggle to remove the pulley bolt if you have never removed it in the past.
    If your NSX is AT or very early Acura MT model, then you need 50mm HEX at the crank pulley.
    You may already have this tool if you or your mechanics worked on other Honda cars. Most of old Honda models use 50mm HEX.
    If your NSX is MT and not the very early Acura MT model, then you need 45mm HEX.
    I heard from another member (and just saw NSXGB's post above) that other tool manufactures sell similar tools but I have never tried them by myself so can’t tell the ease of use.
    07JAB-0010300: Holder attachment, HEX 45mm. GBP45.40+VAT
    07JAB-0010400: Holder attachment, HEX 50mm. GBP31.97+VAT
    You will also need this handle to hold the attachment unless you have other method.
    07JAB-001020B: Handle GBP44.01+VAT
    These tools are not cheap considering their fairly simple design so you may want to source them from other places such as Amazon, Laser, Sealey, etc.
    Some of the HEX attachment tools have square opening which allows you to use your breaker bar as the handle (as in NSXGB's post).
    Again, I have never used these non-Honda ones so not sure about the fitment.
    Thanks for that Kaz.
    My car's a 2002 3.2 NA2 so I assume it's 45mm.
    I have a deep 3/4" drive 45mm impact socket and a fairly powerful 3/4" drive impact gun (the same one used to remove lorry wheel nuts) so hopefully that will shift the nut!
    Failing that I could use a 3/4" drive breaker bar to slacken it.
    Do you know off hand what this nut should be torqued to when fitting the new pulley?
    Quote Originally Posted by duncan View Post
    See attached photo;
    Very resourceful and inventive of you! Well done.
    I've ordered the tools from Honda anyhow under the part number Kaz gave me so they're cheap enough anyway.
    Quote Originally Posted by gcon45 View Post
    Lucky you to have access to 3/4" gun.
    For 2002 MT car, it's 45mm.
    I presume you are re-using the existing pulley bolt so the torque is 245Nm.
    Please follow the Workshop manual on which area to be cleaned and lublicated at the pulley bolt. Otherwise, you will really stuggle to remove the bolt next time.
    On some of the NSX, I had to apply more than 700Nm to loosen the bolt.
    You need a 19mm impact socket for the crank pulley bolt. The 45mm is the size of the crank pulley holding tool.
    Attached is some info courtesy of Kaz that you will need.
    CrankPulley.pdf
  5. #15
    Many thanks Kaz!
    700Nm
    Wow
  6. #16
    CrankPulley.pdf
    Cheers!
  7. #17
    All sorted now.
    Thanks for the replies chaps!
