It looks easy to change but I've been quoted £150+ from Honda for the part.
Does anyone know of a cheaper source? Is the same part fitted to other Honda or non-Honda cars?
Gary
Gary
This may or may not be a common fault but it is niggling nevertheless.
I cannot get the rear window to latch closed. When I apply pressure above the latch there is an audible click but when I release my hand it pops off again. Obviously, the latch needs adjusting but in words of 2 syllables or less, how is this best done??
Thanks,
David
1999 3.2 Manual NA2 Targa in Formula Red
Take a look first at your "engine bay lid", make sure the rubber seal is seated correctly and nice and tight against the lid. [Not the seal on the glass hatch, but the seal on engine bay lid]
If it is then yes try adjusting the catch, adjusting the catch is a trial and error process, you dont have to lremove the bolts but rather loosen slightly [dont remove] and tap the catch gently up or down, be careful not to over torque the bolt when tightning again.
Other things to check is the boot release handle is seated correctly and not catching the trim and also that the cable is not stuck or jammed.
I'm working on a Nissan 300ZX at the moment and the boot was doing the same thing, turned out that one of the boot trims was catching the cable and everytime the boot was closed, it would spring up again.
Thanks Sudesh. Kneading in the rubber rim of the engine cover around the latch did the trick. It seems that when I open the engine cover, the fit between its outer edge and the window's lower edge seems almost air-tight such that I have to push in the rubber seal a tad to get the latch to lock. All part of the learning experience!!
http://www.nsxprime.com/forums/showthread.php?t=75746
hello friends , that made a long time that I n' but, I did not post am always, considering this topic, that made fear, my NSX has 162000km, have a good address to buy this pulley and all the kit distribution in Europe or with the United Kingdom , it is better to change this pulley before breaking the engine!
Hi, Thunder.
Not sure I understood your post but additon to the post on Prime, you can find some info from post #90 in the following link;
http://www.nsxcb.co.uk/testvb/showth...?t=6286&page=9
and post #92 in the link below;
http://www.nsxcb.co.uk/testvb/showth...t=6286&page=10
Parts No;
13811-PR7-A02 for MT
13811-PR7-A11 for AT
You need different pulley holder tools for MT and AT.
HEX 45mm for MT
HEX 50mm for AT
You can replace the pulley without disturbing the timing belt or the lower cover. Just needs to re-adjust the tension on both ACG and A/C belts.
Make sure to follow the latest greasing/cleaning procedure on the pulley bolt. Otherwise, you'll really struggle to remove it in the future.
Also, if you are struggling to get hold of the parts, you may want to try contacting Andy at Vtec Direct Ltd. You can find the link in the 'NSXCB Vendors' section of this site.
merci beaucoup, ma langue est le Français, le traducteur Google est tres mauvais, merci pour les renseignements!
thank you very much, my language is the French, the Google translator is very bad, thank you for the information!
can't park it inside my house.
