Page 5 of 78 FirstFirst ... 345671555 ... LastLast
Results 41 to 50 of 772
Thread: NSX Refresh
  1. #41
    Sudesh Guest
    I didnt have new seals to replace the old ones and after speaking to the owner we decided to try the holes at the bottom method first.
    So I cleaned up the seals and the body of the car, and also used some waterproof bond when re-installing.
  2. #42
    Sudesh Guest
    With the boot having some damp before I cleaned out the antenna drain hose, I decided to remove the rear lining.
    There was some dirt/grime and the boot had a damp smell to it
  3. #43
    Sudesh Guest
    Im left the boot lining out and lid open over nite to air everything out.
    The following day, I Cleaned up the boot floor and used some WD40 to help with removing any surface damp/rust and its also good and leaving a clean smell lol.
    I re-installed the carpet and cleaned everything up, the CD changer was removed also. Much better now
  4. #44
    Sudesh Guest
    The owner installed a new battery before the car arrived with me. After inspecting the battery cage I noticed the brace was quite bad looking and was rusting. So I removed the bracket and sanded it down slightly, the rust was actually well bedded in and not just surface rust.
  5. #45
    Sudesh Guest
    I mentioned this a few months back; while removing the bracket I noticed the battery cage was actually holding water:
    I removed the the complete setup
  6. #46
    Sudesh Guest
    You can clearly see the water in the cage and also there was quite a bit of dirt/mud and stones
    The problem I found was there is only 1 drain hole and its sits too high up on the side:
  7. #47
    Sudesh Guest
    I drilled out extra holes on the base of the cage, and cleaned it out
    After that I re-installed the battery with the newly painted bracket
  8. #48
    Sudesh Guest
    The owner also opted for a new exhaust, and headers to follow
  9. #49
    Sudesh Guest
    Did you find any Japanese coins in the boot space?
    James.
    I am Godzilla, you are Japan!
