Sudesh, thats what I call a real/proper refresh! When can you repaint my brake callipers please!? What paint did you use? The refresh carpet looks really well.![]()
1999 3.2 Manual 6 Spd Coupe
Honda's Finest Hour
Thanks! Got some more things to add but its coming along nicely now.
After removing the calipers and stripping the paint etc; I started the process with a few coats of high temp primer, then I used a gold hammeite paint and finally a high temp lacquer.
The carpet turned out well, it took more dye than I thought due to the color, but the final look is fantastic. I also done the door speakers as they were scuffed and marked heavely. I removed the speaker covers and tried to clean them up but, they were too embedded with marks and grime. So I changed the door speaker covers to black which revived the whole look and in my opinion still looks great with the black and tan interior. I also had to change the foot well heater vents, to black, the interior fuse box cover, bonnet pull and other small item that would usually be tan on this combination.
Black and Tan - aye, a classic combo
Seriously, great work - keep us posted on further progress!
ex owner - various Hondas inc 03 NFR NSX-T
Current fun car Lotus Evora 400
Great result, Sudesh.
I always enjoy watching your detailed work.
Hope you will receive the correct coolant hoses this time.
I'll also post something on the coolant system to share the info with everyone. Just need to find some time....
Please keep us updated on the progress.
Thanks for the comments everyone!
Kaz a write up on the coolant system would be good as its such a long job and those hose clips if placed in a awkard position are hard to work with. I took some photos of the coolant job but photos dont show just how awkard a job this is.
The wipers on this car were flaking badly and one of the wipers was painted with a brush.
Wipers were removed and stripped
After stripping I cleaned the wipers with a tac cloth then prepared them for priming, when that stage was complete, I coated the wipers in 3 layers of black paint, then 2 layers of lacquer.
Like quite a few NSX's this one was showing signs of condensation in the tail lights. First thing I noticed was someone was already at these lights and had drilled holes at the top of the lights.
Now I know when some of us do the fix, we drill holes at the bottom, so my guess is that the holes at the top didnt help any with keeping water out and condensation.
So I sealed up the holes and took out the lights:
With the lights removed I noticed quite a bit of dirt/grime etc on the tail light seals and the body of the car:
