Fit the 00+ system, it's a no brainer.
Just fit the S2k modulator if you want to save a few £'s but you will lose traction control function...no great shakes as it is not great!
Been years since I did mine (with the correct modulator), I would say the best bet would be to check out buying as a kit from SOS or Mita. Not sure if Christian at ATR does a kit, probably worth a try too. Unfortunately, exchange rates are not in your favour.
Well worth doing though, one of my favourite upgrades.
EDIT: Parts list here: http://www.nsxcb.co.uk/showthread.ph...2646#post72646
all straight forward, the most awkward pipe is ABS to front passenger side wheel....
S2000 modulator if you don't mind losing TCS, it's physically the same unit, with just one wire position change in the main connector...
adapter harnesses should be plug n play, maybe a tweak for the dash light depending on the original car configuration... and some need an extra connection for the ABS computer reset wire.
think Mita does a kit, SOS does one too, (obvs spec RHD) or party pack order from amayama and the like, but you still need the aftermarket harness adapter.. not sure if Christian at ATR does a kit, tho i know he got a delivery of NSX spec modulators recently
Historically marque specialists re-gassed Citroen spheres. Currently eBay lists new Citroen spheres from £30 up, it would most likely need a thread adapter (I’ve no idea which threads are used Honda & Citroen) but worth a deeper dive?
Citroens (of old) used LHM hydraulic which always came with a warning not use in other non Citroen applications. Delving into the web to find out why . .
Seals for conventional brake fluid are a natural rubber blend which is not resistant to hydrocarbon fluids, like LHM. However, seals for LHM will be a nitrile rubber blend which resists oil based (hydrocarbon) fluids and will also resist conventional brake fluids.
Thus it would appear that save for the thread and sealing flare detail Citroen spheres could be considered.
Perhaps someone with a spare Honda sphere from a converted system could measure the thread?
