Page 37 of 37 FirstFirst ... 27353637
Results 361 to 362 of 362
Thread: Tyres
  1. #361
    For the OEM 15/16 combo (yes, your size info is correct) and not regularly driving the car or not doing many track days, may be Yokohama Advan Fleva V701???
    May struggle finding the rear set in stock.
    I think someone on here with European LHD model is/was using it with good feedback.
    From time to time, I saw concern on the front tyre speed rating (even for the Neova AD08 series) but without knowing how tyres are being tested on the tyre dyno.
    Would be surprised if anyone can apply full load spec at the front without heavily modifying the aerodynamics because at the proving ground, you can feel the front getting lighter/lifting at high speed.
    Though, very likely the insurance companies don’t know these facts and just go with the rating label.
    Thanks for the suggestion. I found a place listing both front and rears of the Fleva as available - about £470 for all 4.
    Same place lists AD08Rs as available.
