Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 141
  1. #91
    So the NSX tax bites back, as my 'little win' on the air-con, only requiring a couple of new shrader valves has now been offset by both the clutch master cylinder & brake master cylinder leaking.........
    I can't find any record of them being replaced previously, in the cars history, so if they are 30 years old & have lasted 188,000 miles, then that's pretty damn good in my book. I remember having to replace the seals on my old Minis & Metros, what seemed like every few months, so hopefully I'll never have to replace them again.
    Clutch unit replaced, brake cylinder on order from Amayama, so hopefully the car won't be off the road for long but if the weather changes as predicted, the S2000 will probably be more appropriate anyway.
  2. #92
    Some pics of the brake master cylinder replacement. Had to give the servo a touch up of paint before fitting the new cylinder, due to the brake fluid having corroded the paint & a slight covering of rust.
  3. #93
    Nice work.
    Hard to tell from your photo but hope you removed the rubber gasket before the touch up.
    If the master cyl was leaking, behind the gasket is where the brake fluid and the rust would sit.
    Very rare but with the worst one I saw in the past, the fluid was actually held inside the booster.
    Yes Kaz, I removed the old gasket/seal before painting.
    The cylinder was obviously leaking for a while but the brakes felt ok but now with a new cylinder I would say the pedal feel is firmer & the brakes feel a little sharper, as a result. I suspect, as there was a small leak of fluid, there would have been small amounts of air possibly getting into the cylinder causing the slight spongy-ness of the pedal feel.
    Now back to fix the Air-Con, as it has stopped getting cold, again..... I suspect the evaporator matrix in the main HEVAC unit.... At least I had a months worth of cold air comfort.....
    Nice work.
  5. #95
    Seems like you are chasing multiple A/C issues one at a time or you still have some leakage.
    If it was fine for a month, I hope it's not evaporator related.
    I believe you don't have the manifold gauge.
    The RS24, R12a, etc are mixed/blended refrigerant so if leaked, the mixture ratio would change.
    As a quick refrigerant level check, take a look at the sight glass on the drier/receiver while keeping the engine rpm above 1,000 - 1,500rpm and the CCU at freezing cold setting.
    Ideally, you want doing this check on a very hot day as the exp. valve continuously changes its needle port diameter altering the pressure but at least, you can see whether you have low refrigerant or not as long as you can engage the compressor.
    Sounds like a bigger leak. You've mentioned that it hold pressure after changing valves etc. Have you ever changed all (accessible) o-rings? If not you'll be faced with a long-running problem with your A/C system.
  7. #97
    I'll give this a go Kaz but the cold pipe (in the front end), which I believe is from the compressor, is no longer cold to the touch. When the air-con was briefly working, it would get cold enough, that you couldn't hold your hand on it, so until I get another pressure check, I pretty convinced the gas has escaped again.
    And to Golds point, I haven't changed all O rings so, I think this winter I will probably rebuild the rest of the system.
  8. #98
    Time for an update to this thread, with this winters project. A partial transmission rebuild, new driveshafts & new clutch.I haven't found any info in the cars history documents, of any replacement or rebuilding of the driveshafts but I doubt that they are untouched in nearly 190,000 miles. They clunk when taking up the drive, so they definitely need replacing. I've decided to replace, rather than rebuild (although I probably will rebuild them & keep as spares) with some from Insane Shafts, as their prices for a pair of 500 HP rated shafts are just a bit more than a single new OEM item from Amayama. I could go down the rebuild but I suspect that current shafts might well be worn too far, for just a rebuild but time will tell.... I am going to rebuild the intermediate shaft fixed joint with new bearings and seals also.
    There is record of one clutch replacement but this was some time ago & the pedal bite is near the top of the travel & there's always been a slight judder, even after replacing a broken engine mount & re-torquing them in the correct sequence. So a new one will be ordered from Amayama, as soon as the gearbox is out & all parts have been inspected.
    So far I've removed the old driveshafts, which sounds quite easy but requires all the lower rear suspension links to be dis-assembled to allow the rear hubs to swing enough to allow the driveshafts to pop out of the diff. They were proving to be a bit stubborn, so I removed the band securing the inner boot & split the joint there & will then remove the inner joint. All the gearbox cables & harnesses have also been disconnected & oil drained.
    Old shafts not fully inspected yet but as you can see, the grease isn't looking the best...
  9. #99
    A little more progress,
    but now Im stuck..... I can't get the gearbox off past this point, it's moved about a inch & I'm uncertain of the intermediate shaft length that engages with the engine side, to know how far the gearbox still needs to slide off the splines. From my memory probably a couple more inches........
    Anyone tackled this job before singled handedly ? That can offer any tips ? They would be appreciated.
    I guess another pair of hands would help no end. Time to call some favours in...
  10. #100
    ^ One thing I have read many times over - did you release the clutch fork release? The one that's held by a spring and needs to be pulled out slightly to allow the trans to separate.
    (Apologies if this is teaching grandma to suck eggs - it's a whole new world to me, and full of surprises and gotchas!)
