Results 1 to 10 of 18
Thread: Antenna assembly
    Default Antenna assembly
    Has anyone got a working or broken OEM antenna assembly? Mine has a vital part missing!
    1991 Red/Black 1974 Triumph Trident T150V
    What part is it???
    Hi Clive. It's the metal cover and plastic ring that guides the toothed belt around.
    This company have a couple of NSX that they're breaking.
    Give em a call you never know.
    http://www.ebay.co.uk/itm/BREAKING-P...item4adae1a2ea
    good luck
    If I remeber correctly, I think the parts in the ANT area were changed over the years so better to check against your specific spec.
    You may be able to use later spec parts by replacing other parts so need to be bit careful on exactly what you want to achieve.
    Also, I think there was a problem with the early model parts and TSB was released on this so if I find it, will send it to you so that you can specify exactly which parts you want.
    Some of the parts could be discontinued.....
    Yes I have a broken antenna assembly from a 1995. I think it is all intact and yours if you want it
    1996 NSX-T Auto
    1933 Talbot 105
    2011 Nissan Cube Rider
    There are two types of people. Those who extrapolate from incomplete data.
    Honestly, the toot we keep in case it comes in handy...
    Never heard of the Man Drawer? I have accumulated an NSX silo.
    1996 NSX-T Auto
    1933 Talbot 105
    I'll take it! PM sent
    Peter
    My 91 antenna quitted to work today. The insulator (no SLO part no.) of a 91 is discontinued but the one of the 2005 is still available (SLO part no. though). The mast is differnent, now SLO part. no. But the cylinder and the tube are the same.
