Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: my DRL's are done..... (there will be pics!)
  1. #31
    Hi John, are you taking orders on these products?
    Scott
    92' Honda NSX
    07' Honda S2000
    02' Honda S2000 (Berlina Black) SOLD
    96' Honda Integra DC2 (JDM Championship White) SOLD
  2. #32
    alas, these are not 'products' just little projects to stop me getting too bored!
  3. #33
    Where do you get 'hot on ignition' 12V in the front compartment. I've found out that the power windows in the fuse box are hot on ignition. I'm about to connect it there as it's only demanding 0.5 A. Any other/better one?
  4. #34
    Or use the front fog connections?
  5. #35
    ignition 12v is in the front fusebox, the only big fuse with 12v switched (and therefore has easy to tap into screw connectors) is the one feeding the window wiper circuit... I tapped into that...
    .... but that's only live with the foglight switch, and turns on the side lights too....
  6. #36
    Thanks for the hint. I've already dismounted the fuse box to get access on the back but the big fuse is easier. Thanks again.
    Foglight switch: some in the US used it but I'm a lazy guy. So I want the DRL running with IGN ON automatically, much more elegant.
  7. #37
    Can we see a picture and are you going on the euro trip???
    I do like a DRL 👍
  8. #38
    I'm not able to join the Euro trip unfortunately. I'm going to post some pics here as soon as it's finished as I owe you some.
    Here you go:
    They are mounted in parallel to the lenses above and at the same vertical height. Yes, they are a little bit curved. This way they don't look 'tuned' or even 'tinkered'.
    britlude's solution is the most elegant but risky over here as I try to avoid any discussions with 'our MOT people' as they are famous for...
ID:	12619   Click image for larger version.
  9. Default
    love them
    is there anyone on here that could do this conversion for me ?
    Dave
