Originally Posted by
Kaz-kzukNA1
Hi, gcon45.
If you don’t have the correct tool or huge impact gun, you will struggle to remove the pulley bolt if you have never removed it in the past.
If your NSX is AT or very early Acura MT model, then you need 50mm HEX at the crank pulley.
You may already have this tool if you or your mechanics worked on other Honda cars. Most of old Honda models use 50mm HEX.
If your NSX is MT and not the very early Acura MT model, then you need 45mm HEX.
I heard from another member (and just saw NSXGB's post above) that other tool manufactures sell similar tools but I have never tried them by myself so can’t tell the ease of use.
07JAB-0010300: Holder attachment, HEX 45mm. GBP45.40+VAT
07JAB-0010400: Holder attachment, HEX 50mm. GBP31.97+VAT
You will also need this handle to hold the attachment unless you have other method.
07JAB-001020B: Handle GBP44.01+VAT
These tools are not cheap considering their fairly simple design so you may want to source them from other places such as Amazon, Laser, Sealey, etc.
Some of the HEX attachment tools have square opening which allows you to use your breaker bar as the handle (as in NSXGB's post).
Again, I have never used these non-Honda ones so not sure about the fitment.
