Page 16 of 28 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 276
Thread: Britludes NSX story
  1. #151
    As always, nicely done, Jonathan.
    On our NSX, one of the worst bracket to get corrosion is the one holding the four orange connectors for the ABS solenoid located just in front of the ABS modulator.
    Quite often, I have problem releasing the connectors from the bracket in order to activate the solenoid manually. I think you already painted it in the past.
    By the way, for the parts page on Lings website, once you reached the diagram showing the parts you want, just delete the text ' _pfk ' from the address bar (remember to delete the ' _ ' underscore as well) and you will get the proper Honda Parts No. instead of Lings in-house parts system no. PFK****.
    Like it: http://www.lingshondaparts.com/honda...block_03=21550
    Saves having to add it to the shopping trolley to see the Honda part #.
  3. #153
    i re-did the ABS connector bracket, just to complete the set...
    before
    10014555_10204150050444530_1688581361046977662_n by jon sutherland, on Flickr
    and after a sand blast to remove the old paint and rust, etch prime and a coat of silver!
    1969334_10204150050124522_5247074592523267756_n by jon sutherland, on Flickr
    whilst i was under the bonnet, i decided the abs pump bracket and motor cover need attention, so just wondered how much a new one is, just to save turn around time and keep the car on the road.... £213 for a piece of bent metal... i don't think so! so later i'll be removing it, blasting it and seeing how it looks! if it's too bad i'll make anew one out of stainless!
    anyway, the replacement vtec seals arrived from rockauto, in a nice box......
    10458866_10204150060684786_8198668921644287449_n by jon sutherland, on Flickr
    nothing quite like a bit of overkill...
    10473776_10204150060764788_4061627140639176246_n by jon sutherland, on Flickr
    yes, that box for the 4 seals!
  4. #154
    in turn, the vtec assemblies were removed and the solenoids unbolted from the housing....
    1521966_10204150060804789_6787287657354360727_n by jon sutherland, on Flickr
    the small seal is shot as i've never touched it, the bigger seal is ok as i replaced that already and is still flexible and round in section, but i renewed all just to make sure!
    the seals were prised out, the units given a blast of brake cleaner and new ones fitted (i forgot to do a before pic, but remembered for the second one!!!
    anyway, here's the difference between old and new. the old was crushed flat, had the feeling of hard plastic, rather than nice new rubber!
    10672430_10204150062444830_1440643851354264743_n by jon sutherland, on Flickr
    here's the pic of the second unit, the rubber seal crushed and hardened, not a lot of sealing potential...
    10345534_10204150062124822_411624823229629285_n_1 by jon sutherland, on Flickr
    here's the new seal in place,quite obvious the difference now!
    10712722_10204150063044845_5032379869548395902_n by jon sutherland, on Flickr
  5. #155
    anyway, fingers crossed i've found the oil leak!
    another clue, i now realise, was that a void in the top if the vtec housing, under the solenoid flange, had oil in it when i removed the solenoid. obvious now as the void is outside the sealed area!
    the square 'hole' at the bottom of this pic!
    10660179_10204150164407379_7924969667752402233_n by jon sutherland, on Flickr
  6. #156
    now the evenings have drawn in, and its cold dark and nasty, i finally got around to a mini-mod/addition to the NSX
    i have (hopefully) a pretty engine, but it's a bit dark to show off in anything other than bright light, so i thought, to be a bit tarty AND make maintenance checks of a gloomy evening easier, i'd add a little light on the matter
    using a DRL that i'd bought as a sample, i put a plan into action!
    the DRL is a cob (chip-on-board) LED array, so is very thin and slightly flexible, and thinner when you take it out of its weather housing! i put in a little bend and stuck this to the underside of the engine cover at the back return edge, to keep it subtle and stealth!
    10639433_10204449972942405_1757407047545968207_n by jon sutherland, on Flickr
    a bit closer....
    1506965_10204449972862403_3291169457523741984_n by jon sutherland, on Flickr
    (excuse the rough black edge, i've tidied that up!)
    the wire was routed under the edge trim, around to the cover hinge area, and down into the engine bay near the air filter. a simple push on/off switch was mounted and the supply wire routed to the fuse box where a spare fuse position and a simple connection fashioned to provided fused power!
    a press of the switch and it's on....
    1920399_10204449971782376_7758959247145516701_n by jon sutherland, on Flickr
  7. #157
    here's the before......
    10647147_10204449974302439_6893789400820042991_n by jon sutherland, on Flickr
    and the after.....
    10731084_10204449973662423_359220037171434773_n by jon sutherland, on Flickr
    that works then!!!
  8. #158
    Oct 2010
    Guernsey
    Very nice, as usual!
  9. #159
    might as well put the new screen in the build thread.....
    132552 miles... a shiny brand new Honda screen with blue top tint fitted....
    oil change tomorrow....
  10. #160
    132656 miles.... oil change!! exciting huh??? but it does show I did over 100 miles today and no-one spotted me!
