Page 15 of 28 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 276
Thread: Britludes NSX story
  1. #141
  2. #142
    had an unexpected day off today, and with the weather being on side too, i thought i'd do a bit of pre-emptive maintenance and cleanup as a bonus too.... the bonnet was opened, and it was a case of take off a rusty bracket, give it a good wire brushing, bake on a bit of paint, and bolt it back in! that was the mission statement, and off i went!
    first was the cruise control side of things.... bracket before
    10678770_10204078599498301_848496985859788118_n by jon sutherland, on Flickr
    and after
    1932389_10204078599938312_1814683536808169530_n_1 by jon sutherland, on Flickr
    10403702_10204078599138292_8809180440225367235_n by jon sutherland, on Flickr
    i separated the base plate from the cruise control, derusted and repainted. all back together with some pretty stainless washers
    10398024_10204078600458325_9140423465820087405_n by jon sutherland, on Flickr
  3. #143
    then to the other side..... removed the brackets from the fuse box, and relay boxes....
    10698609_10204081612253618_5552043440616159265_n by jon sutherland, on Flickr
    10712936_10204081617253743_254399148745759264_n by jon sutherland, on Flickr
    the overall effect... before
    10670216_10204081610413572_7430880218120510212_n by jon sutherland, on Flickr
    and after
    10440751_10204081624173916_1836591250494275192_n by jon sutherland, on Flickr
  4. #144
    it would be rude not to tidy up the spare wheel bracket....
    the usual look
    10304496_10204081619173791_4978769151299990801_n by jon sutherland, on Flickr
    after 10 mins with a scotch pad thing on the bench grinder!
    10155354_10204081621253843_3559524947768521551_n by jon sutherland, on Flickr
    (i know the top rubber is missing, i made one up when it was refitted with some sticky-backed high density foam)
    such a nice satin/brushed finish it would be impolite to do the ABS guard too....
    10710986_10204081625973961_2665998361450298247_n by jon sutherland, on Flickr
    all done, re-did the radiator mounts too... now satin and black!
    10653293_10204081632214117_6182230268277571048_n by jon sutherland, on Flickr
    while i was there, i gave all the unions on the brakes/abs unit a blast with Gibbs lubricant, magic elixir/snake oil metal preserver! (as were the bare aluminium spare wheel bracket and ABS guard)
  5. #145
    Great attention to detail again Britlude, I wish I had the same mindset, well done.
  6. #146
    ta,
    while i was chasing a small oil leak (cam plugs are dry, no obvious leaks from the cam cover, dry all the way round, i think its the rear vtec solenoid seal, the one between the solenoid and vtec body and the only one that hasn't been replaced!) it gave easier access to remove the vacuum lines and a bit of plumbing.... of course these we stripped and repainted as they were chipped! tidied up the cross brace at the same time!
    1620421_10204078597858260_1303111323518652833_n by jon sutherland, on Flickr
    this will have to come out again once the seals arrive from rock auto (currently en route in Memphis!).... a pair of vtec body and solenoid seals are listed at £90.80 from Lings, rock auto have all 4 for £38.08 delivered, just search their site on the oem number!!
  7. #147
    The underbonnet brackets ... one of the jobs I did recently and well worth the effort ...
  8. #148
    I have currently got the front of my car in pieces to clean up the brackets. Does anybody know if the rubbers for the spare wheel holder are still available from Honda? One of my side ones and the top one are missing.
    MC
  9. #149
    Yep...You may want to search for your specific year model but doubt there were any changes.
    http://www.lingshondaparts.com/honda...block_03=21550
    Quote Originally Posted by Mistercorn View Post
    MC
  10. #150
    1992 lings listing
    10 PFKL799891 CUSHION, SPACE SAVER TIRE £11.83 (€0.00) ($0.00) 001 Add Wish List
    11 PFKL799911 CAP, SPACE SAVER TIRE HOLDER PIPE £12.62 (€0.00) ($0.00) 002 Add Wish List
    2000 lings listing
    13 PFKL799891 CUSHION, SPACE SAVER TIRE £11.83 (€0.00) ($0.00) 001 Add Wish List
    14 PFKL799911 CAP, SPACE SAVER TIRE HOLDER PIPE £12.62 (€0.00) ($0.00) 002 Add Wish List
    so probably the same beasts throughout!!!!
    looking at mine, it probably only had 1 when i got it, as it looks like i've halved it to fit both sides.....
