Good grief! A part that I never even knew existed; you learn something new every day.
I'm used to those nasty, asthmatic clutch delay valves in the M/C.
Hi Nick,
Yes it's a nice little upgrade but works best with the short NSX-R pedal. I've had this setup installed on my NSX a while now both with standard pedal and NSX-R pedal and obviously works best with the NSX-R pedal [the way Honda intended] as it uses less stroke, so quicker pedal work.
NEW NSX-R Clutch pedal installed
Can be quite awkward to work in there as one bolt in particular is hard to access, but Ive been down this road before was well prepared, just need to be careful and wear gloves as there are some sharp edges on the clutch housing and need to be careful cautious removing the housing out over the clutch master rubber.
OLD PEDAL
Cover the interior so not as to damage seats, sills, plastics etc
disconnect the plug that goes into the clutch switch, release the clutch fork by removing the split pins or R clip depending on year, remove 3 bolts then carefully remove the complete assembly
Remove the old clutch pedal, one big long bolt and push clutch back to lift out of the spring, you dont need to remove the spring but again just be careful around this area.
There is a metal bushing inside the pedal, so take that out
OLD AND NEW PADALS
Put the bushing back into the new pedal
Install new pedal
And the pretty much do everything in reverse.
Clutch stroke is then adjusted to NSX-R spec and bleed system.
nice one ... looking forward to trying it out, hopefully not take too long to get to grips with it
