Results 1 to 9 of 9
Thread: Anyone tried K&N air Filter?
    Default Anyone tried K&N air Filter?
    I used K&N filters in my S2000s and found they were worth having for the slight deepening of the induction noise, and the fact that they didn't need replacing with every annual service.
    I'm not really interested in going for airbox replacement in the NSX, but wondered if the K&N filter 33-2713 (http://www.roadrunnermotorsport.co.u...ir-filters.asp) would make much difference? Anyone using one and would you recommend it?
    cheers, Ewan
    ex owner - various Hondas inc 03 NFR NSX-T
    Current fun car Lotus Evora 400
    Jun 2003
    Yes I have one.
    No I do not recommend it.
    Kevin - Now you've left me hanging
    Why not? Does it not make any difference? Is it somehow worse than the standard one?
    cheers
    Ewan
    Default K&N Filter replacement
    Ewan
    I have the K&N FIPK Kit on my NSX [57 series I think] It looks good, sounds good and cheap to maintain as you clean it with oil. So I can recommend it.
    Simon
    Yokohama_91
    British petrolhead living in Japan
    NSX Club of Japan Member
    NSX NA1 3.2 L Red Coupe 1991 5 sp manual
    S2000 AP1 Red 2004 [the real one that revs to 9,000 rpm]
    Twin Honda Monkeys
    Motegi 2m 19.3sec, Fuji 2m 2.71sec
    I too had one on my two previous S2k's
    I've had one on my NSX for about 3 years and 70,000 miles, and am very happy. Needs cleaning and re oil periodically (I do mine about once a year) and it saves a few squid
    I'm sure if you are looking for optimal performance there may be an argument that it's not as efficient as the standard box, as its drawing warmer air from within the engine bay as opposed to the scoop. I think this is probably so marginal that I can live with it.
    Current toys= MV Agusta Brutale, BMW K1200s, Mini cooper SD, Jaguar XF, Ex S2000 owner
    91 NSX Owner between 16 July 05 and 18 Feb 2011
  6. Default
    Quote Originally Posted by Ewan View Post
    I'm not really interested in going for airbox replacement in the NSX, but wondered if the K&N filter 33-2713........
    I have the same K&N also and love it, I could not find a good deal on ebay so I found a discount coupon here: K&N 33-2713, or you can try one of the vendors on the forum here, you can usually find a good deal that way as well. This was very easy to install and I love it. good luck :yes:
    Hi, all.
    Unless your back pressure (exhaust) is reduced or you have modified the engine hardware/software, I recommend staying with OEM air filter/box unless you want to listen to the extra intake sound (if you can still hear it…) from your aftermarket filter.
    The design of OEM airbox and intake resonance chamber inside the left rear wing is quite special that unless you have modified the engine side, you are more likely to loose the power at certain rpm band based on the dyno data.
    If you are going to use after market one with oil type filter like K&N one, please be careful with the amount of oil you use after cleaning. On some of the NSX using these aftermarket filters, I noticed significant increase of sticky oily dirt inside the throttle body and on the butterfly. Even with the OEM filter, you'll get this sticky dirt but it is from the blow-by gas which is after the filter and nothing to do with the air filter.
    In fact, it’s not the K&N filter issue but it was the users applying too much oil after the cleaning process. So, you may save something but you will spend more time checking and possibly cleaning your throttle body and butterfly than OEM filter users....
    Quote Originally Posted by kzukNA1 View Post
    Detlef may disagree with you!!
    I have just installed the Procar Airbox and air scoop. It does feel more resposive across all rev range compare to OEM....the ARC airbox I had tried just sounds louder but not more responsive.
