This is the tyre size calculator I use.
http://www.miata.net/garage/tirecalc.html
Check and see if it is still within 5% of the OEM rolling circumference difference.
****1997 3.2 Orange / Black SOLD****
Previously driven by.........
Jeremy Clarkson, Tim Harvey, Richard Burns (RIP), Jason Plato, Harvey Postlethwaite (RIP), Manfred Wollgarten, Dirk Schoysman, Barrie Williams.
Nurburgring lap time 8:38 - Honda NSX (sport auto, 08/97)
This is the one I use;
http://www.alloywheels.com/tyrecalc.asp
Use the recommended width calucator to see if those 265 will fit on the rim designed for 245.
Can you make this a sticky?
Done, unless Kev 'unsticks' it .
From my mentor: 'Remember, with great power, comes great responsibility' K.Cooke 2007
225/45/16 front
265/40/17 rear ( Can fit on Rim width 0f 9x17 to 10.5x17)
difference in diameter = 5.75%
Is this acceptable for the car's ABS/TCS ?
What's the standard Rim width on the 94+ rear alloys?
SS, I think the tolerances are up to 5% and within this, it won't affect the TSC and maybe the ABS? Not sure exact size of oem rears 94+? its in the driver's manual, not at home now!
1999 3.2 Manual 6 Spd Coupe
Honda's Finest Hour
TSO,
I also thought it was a 5% tolerance but there many out there with 215/45/16 front and 255/40/17rear which measures out at 5.98% with no problem?!?
