I don't know how good the spare wheel holder/brace is as the GND point when you tried jump starting last time.
In fact, one could accidentally create short circuit by jump starting at the battery especially when the spare wheel holder is in one's way.
Also, seen many NSX with its battery holder bracket in the wrong orientation that the battery positive cable clamp is too close to the metal holder bracket.
The bracket is coated from the factory but by now, most likely peeled off and the metal exposed.
You can't even crank the engine so not directly related but just double check that the 120A fuse inside the same main fuse box in the video/photo below is not blown.
If short circuited or reverse voltage applied, it will blow.
Can you access the Engine (Eng) bay?
In order to prevent the short circuit, there is a proper jump start terminal there on our NSX.
Also, the starter is at the Eng bay so this is the shortest circuit length.
Very old video but provides you with some idea.
You can also use that location for the battery conditioner.
Positive cable at the +B jump start terminal inside the main fuse box and the negative side at the intake manifold.
Depending on the spec of the TH body, the shape of the GND point on the intake manifold is different but you should see negative/minus [ - ] marking nearby.
If not heavily corroded, you can also use the metal tube of the brake booster vacuum line as the GND point.
On my NSX, I wanted the permanent installation for the battery conditioner so wired up in a way to be able to connect at the battery or at the jump start terminal inside the Eng bay.
This will allow me selecting the connection port depending on how I park the car and keep the security/immobiliser armed.
In order to prevent me from moving the car without first disconnecting the battery conditioner, I just cover the shift knob with a glove and big notice board at the steering wheel.
Next time when jump starting, keep eye on the volt gauge.
Turn IGSW into P2 ON, just one position before the cranking.
If the volt gauge doesn't move, you haven't connected the donor electrical power supply properly or you have other issues.
You should see about 12V or above depending on the power source of the jump starter.
Turn IGSW to P3 START (cranking).
Normally, you would see about 10V even during cranking and must hold at least 8V in order to fireup the engine.
If you saw voltage at P2 but no cranking at all (not even slow cranking) at P3, something is preventing the starter circuit.
If slow cranking and no fireup, something is consuming the energy of the donor power source.
Reason: extra info
Bloody brilliant Kaz, it's precisely an idiots guide that I need to fault find. Thanks so much.
I did find an old thread on the forum that talked about it being better to jump start via the engine bay but then someone said they'd done it many times direct from battery. Given the "proper" way requires me pushing the car out the garage, and back in again if I am unsuccessful, I opted for popping the bonnet (front) instead. I have an inkling a may have popped a fuse tbh. Consumable and easily replaceable I assume? Spare already hidden away in the fuse box by chance?
Another dumb question, a Golf R is man enough as a donor right, or X5 a better option?
Jumping the car from the jumpstart terminals in the engine compartment is 'better' because it is usually easier. It eliminates the need to remove the spare tire and reach down and try to clip on to the battery terminals. It also has the advantage that if the cable connections at the battery (including the chassis ground) are in bad condition it eliminates that as a factor. If the cable connections in the car are in good condition you can jump start from the battery location without issue.
I assume that refers to the source for jumping the NSX? Either car should suffice as long as they both have the original style battery - i.e. you have not installed some tiny lithium ion battery.
There are a number of fuses that could disable the NSX starter system. These include the big screw in PAL style fuses like shown in Kaz's photo of the engine compartment main fuse box. The #29 50A PAL fuse in the main relay box (up front) will kill the starting system. However, there are other small fuses that can also kill the system. If the car won't start using the jump cables start turning on stuff (headlights etc) to find out what works while it is connected to the other car. That may give you a clue where to start looking.
Thanks oldguy, will try that if I get that far. Problem #1, opening the bloody fuse box.
It looks like there’s at least 3, perhaps 4 tabs to push in and the one facing the cockpit/firewall, and the one facing across the engine bay (if there is one) look bloody difficult to access. Any tricks or hacks as the kids would say? Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
