Hope you can see the tiny slit in this photo….
I only highlighted one of them.
You will have 5 slits in total on the rubber block with only 4 places occupied with AT.
At each channel/slot for the pipe, there is a slit along the entire channel allowing the pipe to slide into that black rubber block.
If you can clean the side of the rubber block on your NSX, you may be able to see some of the slits.
After the installation, please check that none of the pipes are touching any part of the body work for the entire length of the pipe.
You won’t notice it immediately but after few months or years later, with the vibration, the pipe could get punctured.
Already seen few examples.
