So start with this…
IMG_20231013_125006 by JON SUTH, on Flickr
Open it up to the mess from hell!
IMG_20231013_130816 by JON SUTH, on Flickr
Tale it apart, and clean up….
IMG_20231013_130820 by JON SUTH, on Flickr
Looks ok
IMG_20231013_130828 by JON SUTH, on Flickr
Bearings all felt fine, so decided not to split them and have a pile of needle bearing to deal with
IMG_20231013_130833 by JON SUTH, on Flickr
And ready to reassemble… (using a tube of grease for each axle!)
IMG_20231013_133158 by JON SUTH, on Flickr
So…. Ready for the rebuild….
IMG_20231014_113027 by JON SUTH, on Flickr
Going back together….
IMG_20231014_120729 by JON SUTH, on Flickr4
IMG_20231014_123737 by JON SUTH, on Flickr
The ABS sensor was put in with lashings of grease around the body and in the hub… the ali had corroded and gripped the sensor when I went to remove it (one side necessitating the removal of all the wiring to gently drift it out on the bench…) not doing that again, so well lubed!
