Results 1 to 10 of 21
Thread: Rear suspension refresh (picture heavy, HURRAH!)
    Default Rear suspension refresh (picture heavy, HURRAH!)
    I hope you are sitting comfortably……
    Following on from the ball joint drill and tap for a grease nipple debarkle, the order was place with amayama and tigawa for parts, and once they had arrived, AND I got a free time slot to do stuff, a plan was formed, the car put on axle stands, and then stop for tea….
    IMG_20231005_174448 by JON SUTH, on Flickr
    Fortunately (or unfortunately) I had to buy a commuter car as work moved, so the NSX doesn’t have to be back together for Monday’s commute, which makes a pleasant change….
    Invest in a decent ball joint splitter
    £50 off ebay…..
    s-l1600 by JON SUTH, on Flickr
    IMG_20231006_104741 by JON SUTH, on Flickr
    The replacement parts….
    IMG_20231006_105829 by JON SUTH, on Flickr
    The top ball joint rubbers were getting crusty (I’d already sourced the OEM parts to replace all the rubbers, but the top ball joint was shot so they are now surplus) so I decided as it would be apart, to replace all the ball joint bits…. 178k miles, so due anyway!
    While the suspension was off, might as well pull the driveshafts, one rubber boot clamp had loosened somehow, so it was sliding on the shaft, and possible grease leakage, so needed looking at anyway…
    IMG_20231006_131724 by JON SUTH, on Flickr
    Top ball joint…..
    Hmmmm…. Floppy
    Took the ball joints out of the upright (brute force and ignorance) and gave one a clean…. It sorta cleaned up, but could be better….
    IMG_20231006_171500 by JON SUTH, on Flickr
    And the wheel bearing assembly….. I’ve replaced these before, (I have new rockauto bearings to put in (wholesale closeout at $21 each!!!)) but this one has always niggled me….
    IMG_20231006_171751 by JON SUTH, on Flickr
    Do you see the issue?? it’s shocking…… no? let me zoom in on the area of shame….
    IMG_20231006_171808 by JON SUTH, on Flickr
    Told you it was shocking!!!!
    Now, I knew sand blasting would be too harsh on the aluminium, so I thought I could find somewhere with a vapour blaster setup… then thought that’s just sand blasting with water…. So….. I bought a sandblasting attachment for the pressure washer….
    IMG_20231007_091629 by JON SUTH, on Flickr
    A whole £16, and about £6 for some kiln dried paving sand…. And tried it on the old top arm….
    IMG_20231007_091231_1 by JON SUTH, on Flickr
    Yup, that works, and a smooth satin, not sandpapery rough finish… but first I had 2 broken bolts to sort…..
    A broken bolt, cos you’ve never seen one…
    IMG_20231007_130605 by JON SUTH, on Flickr
    Weld a nut on poorly
    IMG_20231007_130651 by JON SUTH, on Flickr
    The combo of something to spanner on, and the glowing heat of the welder, means it breaks the seal and unwinds!
    IMG_20231007_131056 by JON SUTH, on Flickr
    A quick demo on the pressure blasting, it really is that quick…
    Before and after is quite impressive
    IMG_20231007_134902 by JON SUTH, on Flickr
    As it was all apart, and I had a set of rear calipers, with rebuild kit, half done (for months, with total apathy) I was prompted to finish them….
    IMG_20231007_152722 by JON SUTH, on Flickr
    IMG_20231007_163206 by JON SUTH, on Flickr
    IMG_20231007_163710 by JON SUTH, on Flickr
    And rebuild…
    IMG_20231008_122133 by JON SUTH, on Flickr
    Ready to go back on…
    IMG_20231008_132330 by JON SUTH, on Flickr
    IMG_20231008_132352 by JON SUTH, on Flickr
    And now back to the nice clean uprights….
    IMG_20231008_133012 by JON SUTH, on Flickr
    IMG_20231008_133015 by JON SUTH, on Flickr
    Bought another tool, £40….
    But had to make it NSX specific, of course….
    IMG_20231008_142045 by JON SUTH, on Flickr
    And the balljoint simple wound in, no drama!
    IMG_20231008_142059 by JON SUTH, on Flickr
    NSX tax applies to these….. we all know they are probably £30 IF you know which normal car they also fit….. https://www.tegiwaimports.com/hardra...x-na1-na2.html
    Next up is the wheel bearings, I bought just the bearing/carrier, not the hub too, so you have to press out the hub…. Had to find a proper press, my kit wasn’t oomphy enough
    IMG_20231009_080723 by JON SUTH, on Flickr
    This leaves the inner race behind,
    IMG_20231009_081235 by JON SUTH, on Flickr
    So you have to get busy with a grinder, to carve an edge for the more conventional bearing pullers to work on…. Eventually they move, and you have the hubs…
    IMG_20231009_183945 by JON SUTH, on Flickr
    Then paint the backs, cos you can….
    IMG_20231009_184938 by JON SUTH, on Flickr
    Meanwhile… grotty bolts…..
    IMG_20231010_192155 by JON SUTH, on Flickr
    I could have bought shiny new, but I didn’t, life is too short to dredge parts diagrams, and def too costly… I could have had them replated, a place near me does them by the weight (Phil knows!) but I was concerned about the ‘special coating’ as they go into aluminium, and galvanic oxidisation is a mare, so I decided to clean and reuse….
    Wire brushed off, cos no-one knows what that looks like
    IMG_20231010_192201 by JON SUTH, on Flickr
    Then treated with my fav rust converter/stabiliser gunge….
    IMG_20231010_194749 by JON SUTH, on Flickr
    Pretty much the best stuff I’ve found…
    IMG_20231010_201440 by JON SUTH, on Flickr
    Meanwhile….. you try to find the correct grease for the axle, in enough quantity to do the job in this country… try as I might I couldn’t find the correct honda custard grease outside gaiter kits, trawled google and forums, conflicting arguments for everything, until I happened upon
    IMG_20231011_164622 by JON SUTH, on Flickr
    IMG_20231011_164656 by JON SUTH, on Flickr
    The NSX has tripod(e) joints, not CV joints!
    So start with this…
    IMG_20231013_125006 by JON SUTH, on Flickr
    Open it up to the mess from hell!
    IMG_20231013_130816 by JON SUTH, on Flickr
    Tale it apart, and clean up….
    IMG_20231013_130820 by JON SUTH, on Flickr
    Looks ok
    IMG_20231013_130828 by JON SUTH, on Flickr
    Bearings all felt fine, so decided not to split them and have a pile of needle bearing to deal with
    IMG_20231013_130833 by JON SUTH, on Flickr
    And ready to reassemble… (using a tube of grease for each axle!)
    IMG_20231013_133158 by JON SUTH, on Flickr
    So…. Ready for the rebuild….
    IMG_20231014_113027 by JON SUTH, on Flickr
    Going back together….
    IMG_20231014_120729 by JON SUTH, on Flickr4
    IMG_20231014_123737 by JON SUTH, on Flickr
    The ABS sensor was put in with lashings of grease around the body and in the hub… the ali had corroded and gripped the sensor when I went to remove it (one side necessitating the removal of all the wiring to gently drift it out on the bench…) not doing that again, so well lubed!
    The other side was built up to the same stage, as I was waiting for the brake back plates to dry…
    IMG_20231014_132537 by JON SUTH, on Flickr
    These have to go on BEFORE the hubs…..
    IMG_20231014_150452 by JON SUTH, on Flickr
    Disc and caliper on, just need to do the drive shaft nut up uber tight….
    IMG_20231014_151607 by JON SUTH, on Flickr
    Spot the difference…
    IMG_20231014_171746 by JON SUTH, on Flickr
    Before I stripped it all, I noted the rear alignment… basic, but does the trick
    IMG_20231015_133802 by JON SUTH, on Flickr
    Green dot nearly in the gap….
    IMG_20231015_134005 by JON SUTH, on Flickr
    Did you spot the difference?
    IMG_20231015_140256 by JON SUTH, on Flickr
    IMG_20231015_140301 by JON SUTH, on Flickr
    Yup, crusty, I did have a go at powder coating these a few years ago, but I obvs didn’t get it right, mostly, but not completely!... so….blasted, it’s steel, so dry is fine!
    IMG_20231015_150736 by JON SUTH, on Flickr
    Rust treated, and painted black…
    IMG_20231015_182952 by JON SUTH, on Flickr
