Hi, The radiator on my car has developed a very slight leak . Should I buy an aftemarket radiator or has anybody had their radiator refurbished ? If so, where did they have the work carried out ?
Koyo all the way.
As above, direct replacement to OEM install as shown …
Yes, I got a Koyo.
1996 Green NSX-T manual
Looks like an aluminium radiator is the way to go. Do I need to purchase any other parts apart from new hoses and clamps. Where is the best place to purchase a Koyo radiator?
You'll probably not beat a Black Friday deal at Torque GT:
https://www.torque-gt.co.uk/koyo-per...iator-nsx.html
I certainly couldn't find cheaper when I purchased this time last year
2001 NSX-T Manual in Imola Orange Pearl
1994 Honda VFR400R NC30 in Castrol Colours
Hi, i have been on the forum and noted that a rubber seal from Toyota/Mazda is required for the radiator replacement . Does anybody know the part number ? Is a new drain plug also required from Koyo ?
I've installed a KOYO rad in mine. I don't know what seal you are referring to. The new rad comes with the drain plug and the rubber seal required for it.
