Have you tried Brembo ? May be a little pricey but they should have them and on the rear they will last a long time. I've got them, slotted, on my car and never had any problems.
cheers
nigel
cheers
nigel
If you are 100% sure that it's for the Rear AND the rear brake caliper is of 97+ sepc, then if you are after the EBC Plain Disc, it's D7353.
You may have already tried but seems to be a few options available on ebay.
Rockauto has several options but not sure of the delivery charge for such heavy item.
There are several options in Japan, mainly from Dixel but the delivery could be the headache.
I'm also struggling to find the reasonably priced alternative method to Japan Post as I can't move the parts from Japan just yet.
As nigel mentioned, there are several other known good brands out there so you may want searching for them.
Just make sure the one advertised is actually the correct spec for your NSX.
Also, check that it's actually in stock and also the return policy.
It's quite heavy and may cost a lot if the buyer takes care of the return fee.
On several occasions, I heard from owners that although it stated that it would fit their NSX brake spec, it was not the case on delivery.
I'll have a look see and try and find my paperwork from back when I got mine.
