Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Gauge Cluster Tester Mark II
    One big dial is still missing, the speedometer. The exact design of the corresponding signal can be found in this forum entry.
    Utilizing the new hardware, a separate driving circuit is no longer necessary. One of the output drivers that provide ground can be used to simulate the VSS (Vehicle Speed Sensor). It was a little surprise to me that everything worked right away:
    Testing the speedometer should not take too much time as the odo and trip meter starts running, too. All bench testing combined already put about 20 km on the car without moving it an inch ..
    The number of cables running towards the gauge cluster in above video increased significantly. A nice example why bus communication became, at some point, necessary for modern cars.
    All main functions are running now but three minor issues have been detected and need to be corrected in a new PCB design. We'll talk about those in the next days.
    This is the final update to complete the circuit and PCB design. Two issues have been observed while prototyping the tester:
    • The output drivers are too weak to supply the gauge cluster illumination (driver chip overheats)
    • The output drivers internal voltage drop is too high for the fuel gauge (doesn't reach maximum)
    • Not enough ground pins
    There has been some delay as the parts required to solve above issues where stuck in transit for almost two weeks, sorry for that.
    Let's have a more detailed look at the problems and their solution.
    Weak Output Drivers
    The cluster's minimum current usage is ~1 A (at 12 V). Enabling all warning lamps pushes it over 3 A, adding illumination results in more than 4 A. Summing that up we are looking at ~50 W being used by the cluster (with illumination switched on). As most of that current is distributed across a large number of pins it's not a problem for the tester but illumination draws ~1 A across two pins with the left connector being responsible for 2/3rd or 0.75 A.
    Each driver output pin can provide ~0.1 A. Enough for most of the cluster but not for those 0.75 and 0.25 A illumination pins.
    Driver chips with similar characteristics but higher output rating aren't available so it becomes necessary to add more punch to the affected illumination pins by means of a discrete circuit. Out of curiosity, the decision was made to realize it with MOSFET transistors. Those are more and more common today as they typically have very low resistance, fast switching and are often controlled digitally with high frequencies.
    Only the first of those main advantages serves as a bonus in this application but the others won't hurt either.
Name:	Screenshot from 2021-02-13 14-31-09c.png
    The circuit ..
    .. the wire connected MOSFET ..
    .. and the result
    The internal resistance of the MOSTFET is so low (0.05 Ω in case of the IRF5305 used here) that it could handle up to 30 A and therefore didn't even get warm during testing. Note that another pull-down resistor is required to avoid the problems observed during RPM gauge control. Case closed, on to the next change.
    Too high internal Voltage Drop
    Driving the fuel gauge is done by periodically pulling down the reference voltage from the cluster to ground (PWM control). If it's permanently pulled to ground the gauge exceeds the "full" level. Unfortunately, the output drivers have a minimum voltage drop associated with them that prevents a complete pull to ground. The needle stops a few milimeters before hitting "F" so that gauge is not fully testable.
    As mentioned above, MOSFETs feature a very low internal resistance (and a corresponding low voltage drop) so using one of them instead of the driver IC should solve the issue. As the order of the was delayed by several weeks it took a while until the circuit could be tested.
    The circuit ..
    .. more extra wires ..
    .. and it works
    The selected IRLD014PBF can be directly controlled by the Arduino and provides an internal resistance of 0.2 Ω. As the fuel gauge is specified to display "F" at 3 Ω, that is indeed low enough as it can be seen above.
    Final location of the two MOSFETs and the one pull-down resistor was decided to be between the two green connector sockets. The 3D view of the PCB editor provides a nice preview of them on the final PCB:
    Not enough Ground Pins
    After one more careful review, new PCBs are going to be ordered. These will include a few more improvements (especially related to layout and pin numbering) and an additional ground pin. Most of the changes can be covered in software but one or two wires need to switch positions on the connector to make everything work.
    Remaining Steps
    Several items remain on the To-Do-List before the project can be considered done. One of them is to be able to return my cluster to the car which means the connection cable to the cluster needs to be documented and a PCB created that allows to check copies of that cable without connecting it to a real life cluster.
    One more important step is to provide a cable supporting the <1995 clusters. As no such cluster is available to me, Drew from NSX Prime is gonna help with that.
    To be able to continue working on the software without risking to break functionality an old Legend cluster (374,000 km) was acquired and needs a matching cable set, too
    A significant amount of work but very much looking forward to it
    As always, full of professionalism, I look forward to the end result of your wonderful work
    Thank you very much, that keeps me motivated
  5. #15
    looking good, nice to see useful stuff being designed and made
  6. #16
    Thanks Jonathan
    Double checked the changes to the PCB and layout this evening, correct some labels and going to order the new PCBs on Monday.
  7. #17
    Long time without an update but since work, home schooling and home kindergardening started again, time for hobbies became limited.
    The ordered PCBs arrived end of January. Valuable parts were remove from the previous board (like the JAE AG5 connectors and CMOS ICs) and moved to the new board.
    It took about 1.5 hours to fully assemble it (excluding the connection cable) which, in my opinion, is a respectable speed-up compared to the old version
    soldering done
    parts attached
    a quick test run
    The new PCB features features almost 200 additional labels, identifying Arduino pins, starting at the microcontroller's output, across the output driver ICs and up to the cluster connectors. This will help to diagnose any issues while developing new cable looms or if something should behave strangely.
    As the pinning and internal signal routing was optimized, software changes had to be made as well as a hand full of pins changed at the connector. When this work reached the cluster's illumination, strange things happened: The backlight was permanently on, couldn't be switched off and the MOS-FET transistor became fairly warm - turned out I had misread the circuit diagram and created a PCB with inverse MOS-FET pins. Nothing that can't be fixed with two cuts and repair wires but a little disappointing nevertheless. It's been fixed in the circuit design and is going to be reflected in the next order (the diagram in above post has been corrected, too).
    As I'm cooperating with @drew from NSX Prime a second tester was assembled and with experience from the first round, it took only about an hour. To visually spice things up a little, a white OLED display was chosen - the price is nearly the same, otherwise pin and software compatible.
    a second copy
    white OLED close-up
    full featured christmas tree
    Besides the tester, a working setup needs a matching cable loom, too. With a bit of experience, the crimping and assembly takes a little more than an hour of slightly brain numbing work. Much less than the soldering and shrink-tube intensive work for the previous generation tester. All that's needed now is an addition 12 V barrel connector power supply with 5 Ampere.
    wires cut to length
    stripped wire endings
    ~60 pins crimped
    For the >1995 clusters I would consider the work done. Remaining tasks are documentation (BOM, etc.) and the <1995 loom, of course. As of today, the software and loom is tested to support 100 % of the display functions on a JDM 1997 AT non-Targa NSX cluster. Looking at the available pinning information that should cover more than 90 % of the functions on all >1995 NSX clusters. Support for <1995 clusters is being created with the help of drew.
    Nevertheless, there are still combinations that are not tested yet (e.g. targa warning light, immobilizer indicator, etc.) and I'm looking for members that would like to support - maybe combined with a capacitor replacement and calibration. Please contact me if you're interested in such an activity or in a tester and loom for your own work.
    PS: With the right software and loom, the tester should be able to drive many Honda and other clusters from a similar age. A 1994 AT Honda Legend cluster will be the next candidate on the list as it should allow me to put my cluster back into the car but to still have equipment available for tests.
