further down, the sensor gears look ok.....
Sensor area... by jon sutherland, on Flickr
the gears dont seem to have any missing teeth....
IMG_20190303_112845 by jon sutherland, on Flickr
D1guy on NSXprime has pics of these with teeth broken off, so I shall check the HPC catalogue and see what they have, i'm sure it'll be a standard metric MOD pitch
...just now got to get the steering input housing bolts to shift.... bent one tool, just broken the tip off the 'lifetime guarantee' tool i just got in specially, literally lasted 20 seconds! ! that'll be going back then! Honda used security torx bolts, so it needs the 6 spline key, but is 'security', so has a pin in the middle...... this means the tool has a hole in the middle, so is significantly weaker than the usual tool .... having been assembled for 26+ years it's reluctant to move....grrrrr
