2003 Hartge Mini Cooper S (2 x UK & 1 x European sound quality finals winner) 🏆
..............and guess what, it was a RED one but of course.
Might be worth trying .. is there a preferred way to do that or should I just open up the Bazaar here ?
Heineken's Garage
OK , let's start with some data from the JDM parts list:
Code:2x 33101-SL0-305 円 145,328 Headlight unit 2x 33102-SL0-J02 円 105,774 Igniter 2x 76101-SL0-A02 円 80,576 Retraction mechanism 2x 76150-SL0-A02 円 77,352 Retraction motor 1x 76120-SL0-A00ZZ 円 30,033 Lid (headlight cover, one is broken) 1x 33108-SL0-003 円 99,328 Inverter unit (HID) (only one needed) ---------------- 円 538,391 ~ 3.610,45 GBP
Above prices are for brand new parts but could .. maybe .. eventually .. serve as a (very) rough indication .. towards .. used parts ..
Heineken's Garage
Gordon Murray knows.
Rowan Atkinson knows.
It's the Honda NSX."
(J. Clarkson)
Hooooly cow.
Super cool conversion, but with a price tag to match!
Do you know if the harnesses are plug and play?
Jeeps.... at that price..I’ll build my own....
£ 201
I did warn you that they weren't cheap! The bulbs are a pretty price too.
The inverter unit is much cheaper (half the price above) from JP-carparts.com
The retraction mechanism & motor are similar if not the same as on the non-hid lights, so maybe you can get away with just the igniter, 2 inverters and the 2 HID bulbs.
December '99 GH-NA2 110 series - 6AS62 Type S in Monte Carlo Blue Pearl
The Honda HIDs are notoriously expensive and the harness is unfortunately not plug and play, especially as the inverters are located near the firewall on the passenger side so extra routing is necessary.
The technical design is also a bit special: The inverters are without the ignitor coil. That one is located near the bulbs.
As the lights do not have any e-marks they are probably illegal in GB (although I'm not sure).
If someone would want to install OEM HIDs he would need the Headlight Unit, Igniter and Inverter. The remaining parts should be compatible.
I'm kind of sorry for spoiling the fun but even the regular Halogen headlight unit is at around 90,000 円 already so it's the usual Honda OEM price madness..
Me personally, I'm would consider the OEM setup only for the die hard "full original" guys due to price and complexity.
There are plenty of kits and NSX assembly instructions available online for a retrofit, obviously much cheaper and easier to install than the OEM setup
Heineken's Garage
Indeed - even a high quality kit with decent bulbs (what else..?) is not that expensive and is plug & play.
Nick
