Check out my build threads last few pages. It's from when I replaced the clutch assy on my car.
http://www.nsxcb.co.uk/showthread.ph...e-fresh/page12
Parts # as above advices.
For the grease in UK, you can get the Honda Super High Temp Urea grease #08798-9002.
It was on years of back order but got back in stock although with bit extra price tag.
I think it’s about £25 for just 50g tiny pot – size of small egg.
If the same chemical, green-ish colour.
Honda one is safe on metal-on-metal as well as metal-on-plastic application.
I prefer the molybdenum fortified dark grey UM264 but very expensive and unless you regularly work on the specific area, never going to finish it as it’s in large tube.
Hi, I am going to order the parts but they appear on different pages in the parts catalogue . Can someone please check that I have the the correct part numbers for the diff seals ( 91206-pr8-005 and 91207-pr8-005 ) and the main oil seal ( 91214-pl2-003 ) for my 1991 NSX.
- You may not post replies
- You may not edit your posts
Forum Rules
