Results 1 to 5 of 5
Thread: NSX-R diff oil change intervals?
    Default NSX-R diff oil change intervals?
    The NSX-R diff seems to ask for more additives in the MTF than the standard diff. After 4k miles the diff started to slightly acting up when I drove a sharp turn out the parking space. Time for a change. Does it need to be changed with the NSX-R diff more often? Anyone with experience with the NSX-R diff?
    Aug 2011
    South Wales
    AFAIK, the NSXR diff is the identical helical diff as fitted to all NSXs. Maybe the ratios account for different service.
    Just use OEM Honda MTF
    Not another NSX project!
    Porsche 997 GT3
    Porsche 981 Boxster S
    BMW E46 M3
    1998 NA2 Midnight Purple Targa Manual - Gone - to Thailand
    1999 NA2 Kaiser Silver Manual Track Car - Gone - and found its true destiny on the race track
    1992 NA1 Sebring Silver Coupe Manual -
    Gone (although still in my showroom in storage)
    The NSX-R in my 91 is a clutch type diff, not sure about the later years.
    I'll fill in MTF in the tranny tomorrow and hope to last it a little bit longer. Some people have brought up the idea of Motul gear 300 LS 75W/90 or even a mixture of both. Not sure what to think about it...
    Aug 2011
    South Wales
    Ah, its an aftermarket LSD then?
    Do you know which make?
    Yes plated diffs need different oil. I would recommend Kaaz diff oil. Ive use that on all my plated diffs and works very well.
    Porsche 997 GT3
    BMW E46 M3
    I've the NSX-R with the stiffer setting.
    The MTF works good but not that long. I'm looking for one holding longer without major disadvantages. MTF is very thin. During gear changes I can clearly hear the synchros whining shortly which is a good sign.
    EDIT: MTF changed, near to none abrasive particles in the oil and filter, very clear fluid. After a short test drive all is fine again. Let's see how long it takes...maybe I was a little bit too encouraged after my gearbox rebuilt and wanted to have fun with the stiffer diff...
