7 years ago I did this conversion, was pretty straight forward from memory. Only difficult thing was recollection and moulding the panel.
cheers for that will keep it in mind.
once again, your the master and thanks for the input, its very much appreciated. I shall find a suitable source that is the neatest for this setup.
yup its your fault I did it this way I always give you credit if anyone ever asks about it
I did this mod for Andrew, he liked NSX-R steering wheel but want to keep cruise, so I did this mod back in 2007
Yup and still working well
Thanks Andrew, and as you you know, if Any issues I will repair Free. It was you big man, that challenged me to do this desiine.
does anyone know,how,to,increase the speed limit on the cruise control when at 116 km/h?
I'm assuming it would mean interrupting the speed signal that is going into the cruise control unit?
Based on earlier post and the speed limit level you are talking about, I believe you own JDM spec.
If your NSX is non-DBW, you can modify the speed signal into the CC unit but please pay extra attention on where and how you break into the wire if you have other controllers such as AT, EPS, etc.
There is another way by applying certain modifications and I have been using it for nearly 2 years.
No issues and happy with the result.
It's not my know-how so I can't disclose the method and since other owners paid for it, I can only offer it as a service at my place.
