KW V3 coilover - special offer!
One of the best coilover kits available for the NSX now in special offer at A.S. Motorsport
Contact me for pricing.
Lowering 20-55 mm
The KW V3 uses state-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
- Damping technology with individually adjustable rebound- and compression technology
- inox-line* stainless steel technology
- Individually height adjustable
- Adjustment parameters approved by the German Technical Control Board (TÜV)
- High-quality components for long durability
- Infinitely variable rebound damping adjustment
- 14-way adjustable compression damping
- Unique, individually working damping force adjustment
- Comprehensive documentation for easy use
- You may not post replies
- You may not edit your posts
Forum Rules
