sorta boring update, mainly because there are no pictures!
occasionally i have been getting a 'knock' from the front suspension when i go over bumps. I have a particular bump on my way to work that i can't avoid if the traffic is wrong, so have been getting reminders on a regular basis!
The MOT didn't show any play in the suspension joints (although i had taken the precaution of sorting some bare uprights for new ball-joints that might be needed later) so i'd had anti-roll bar drop links ready since xmas! finally got a free minute to fit them!
before removing the drop links, the anti roll bar was given a firm wobbling, and a slight knock in the joint area found on the drivers side (always nice to find something!)
fitting was fairly straight forward after the old ones were removed, a combination of fighting with corroded threads and allen key sockets before employing an angle grinder!
no pics, but imagine a dirty black bit being replaced with a shiny new bit! with plenty of grease on the threads and allen socket!
i cleaned the front suspension at the same time, with the simple green precision cleaner stuff!
