AR, what's made you want to move away from the SC?
In most markets the 3.0Ltr cars were quoted as producing 270hp as standard.
Our attempt to get a good selection of NSXs on a dyno in the same place at the same time so as to normalise some existing dyno readings saw the standard 3.0Ltr cars making a touch less than less that (average 262hp), possibly due to their age as Dixon says. See table here... http://www.nsxcb.co.uk/index.php?categoryid=26
As AR says both 3.0Ltr and 3.2Ltr cars respond well to having a decent exhaust fitted and the 3.0Ltrs also respond well having their restrictive cast iron exhaust manifolds replaced with tubular ones a.k.a "headers" in Americanese.
SS's car already had "headers" and a better exhaust as well as being de-cat'ed so, if everything else was as it should be, should have been making around 285-290hp prior to having the SC fitted.
Mark
More power really, nearly 380 is great fun but you soon get used to it. Then you want more and since if I want to go high boost reliably I will need to get a the very least an AEM FIC to sort out the fueling. If I am doing that I might as well get a Turbo, since the main reasons I see for a CTSC is that it is a DIY system that does not require mapping. The hardest part is changing the plugs, and that only because my hands are too big. :)
A Turbo is to very simple to install, and the mapping, well I am still waiting to find a reliable mapper close by. Might end up using Amo's mate.
My goal is 450 BHP on a standard engine IC and MEth cooled for the near future.
For now the SC is great and quicker than a R8 V8, but a Big T is Murcielago territory. :)
Ary, when you go the big T way, are you upgrading your stoppers aswell? In fact what braking system have you in place now? Power is useless without control. :)
Stoppers have better pads ATM and is fine for now. I am looking at several different systems after having a system on order only for the company to change price ( local company nothing to do with NSXCB vendors ) on a set of 6 pots.
Also my car is very light.
As per Luke's thread on big brakes, the number of pots/piston is somewhat irrelevant. Your biggest challenge is getting sufficiently sized discs in the front wheels.
Kevin went through this with Hi Spec and Rob (Fenn) with AP so they may be able to help with the part number required.
Mark
