EPS Controller Service 01
, 02-12-2012 at 10:47 PM (5807 Views)
Being contacted by one of the garages to
service the EPS – Power steering control unit.
It’s the famous ver.023 unit and all of them will eventually
fail sooner or later.
In US, Acura released TSB to have it replaced with later spec one but
this didn’t happen for the UK market.
Seems like water ran down around the controller box and also
the connector housing showed some rust and again,
the traces of moisture.
The original relay inside the 023 version EPS controller didn’t have
enough current capacity and the contact will burn out.
The representative told me that this unit triggered EPS error code #22.
Typical phenomenon when the relay contact has burnt out.
Later Honda replaced one of the two relays with high current capacity one.
I’ll be replacing both relays with high capacity one and
this will require drilling additional holes on the circuit board.
Very delicate process as I don’t want to cause any damages to
this super expensive board.
The original relays that are not up to the task of EPS.
The back of the relay.
The top and bottom terminals will be 3 pin style so need extra holes........
I won’t start drilling the holes until I have the despatch note from
the parts supplier.
Exactly the same relay used on later spec EPS controller is
only stocked in US for some reason although it’s manufactured in Japan.
Due to Thanksgiving holiday in US, it’s taking longer than usual for the delivery.
I hope I can get the parts some point this week.
