A/C Climate Control Unit (CCU) 01
, 14-02-2011 at 11:20 PM (5041 Views)
Initially, we didn’t include the A/C Climate Control Unit (CCU) in the service menu.
It was a good call to change the plan.
Although the owner didn’t report any issues with his A/C, the CCU capacitors were already leaking and started to bite into the board…
Looks like I'll be spending sometime with this board....
Also, the Cabin Temperature sensor was making some noise.
There were lots of dust/debris around the sensor housing.
Message to the owner:
While the centre console is out, I would recommend havng it serviced.
It will save some labour charge than doing it later on alone unless you want to do it by yourself.
