Front Brake Inspection 01
, 08-02-2012 at 10:37 PM (2003 Views)
The owner was told by the MOT place that his Front brake was showing more than 20% of imbalance between the Right and Left corners.
I overhauled these callipers in 2010 so about 1.5yrs ago and it went through several services by other places without any issues so wanted to have a look by myself.
We are also replacing the brake hoses and the master cyl for other reasons so before disturbing the Hyd system, removed the FR calliper and operated the brake pedal with my hand.
Both inner and outer pads were not glazed and the surface was evenly pressed against the disc. Also, they were not seized to the bracket.
As expected, both pistons smoothly pushed out by the pedal pressure and each pistons werer pushed back by the finger with ease.
The upper and lower slider pins were moving smoothly so the FR side looked to be fine.
Will check the FL side tomorrow.
The pedal feeling felt quite stiff compared to my NSX that had its brake Hyd system bled after the recent Eng Refresh. Pedal feeling will be significantly affected by the pads so can’t do a direct comparison but I already have the later spec calliper, latest ABS, etc that are the same as this NSX and I’m using the Type-R pads which is very hard on the disc so would be interesting to see how it feels after replacing the master cyl and brake line.
Will also apply small pressure through the master cyl using the pressure bleeder to feel by myself the actual friction level at each corners. May even take it to my MOT place to check the balance.
