View RSS Feed
Heineken's Garage
Climate Control Unit (CCU) - Repair
Rate this Entry
Introduction
Failure of the Climate Control Unit (CCU) is a common fault, affecting nearly any NSX. In almost any case, capacitor replacement and track repair will fix all issues. Depending on the state of the PCB, further damage to other components can happen, though.
Diagnostic - Transistor Issues
The following error cases and ways of repairing have been identified so far. These faults can be caused by major acid leakage affecting nearby transistors.
Interior fan working only in automatic mode
If that's the case, regardless of the dial setting (don't mistake it with a CCU that works only on the highest dial setting) it can be related to a faulty Q17. The transistors Q14 to Q17 are level shifters providing the position of the fan speed dial to the large Microcontroller.
They are NPN transistors with an internal 4.7 kΩ base resistor (NEC A1L3Z). Such parts are no longer available as a direct replacement but still sold in SOT 323 SMD packaging (ADTC143TUAQ) - which requires appropriate adaptation work (SOT23 adapter PCBs):
AC Compressor and Fans not coming on
.. even though they should (AC isn't OFF) can be caused by a faulty Q9 or Q10. This transistor (NEC AN1L3N) is a PNP type with two integrated resistors: 4.7 kΩ (R1) at the base and 10 kΩ (R2) from base to emitter. Same as with Q14 to Q17 there are no drop-in-replacements available any more. A possible SMD replacement is PDTA143X with corresponding adapter PCBs:
Diagnostic - Specific PCB Tracks
These error cases are related to specific broken tracks on the PCB that are hard to detect and/or who's resulting issues are fully understood.
Full functionality but display stays off
If the CCU shows full functionality but the display and LEDs stay off, it could be due to this broken trace near C44:
CPU stays in reset (no function of the CCU)
A missing connection from the positive pin of C14 to D7 and D6 keeps the processor in a reset loop. This trace damage makes the analog input pins 60, 61 and 62 of the CPU drop to near zero (should be 2.4 V) causing a reset, as soon as reaching below 1 V.
Temporary lifting the analog ground connection pins of the CPU (pin-pair 52/54) from ground should enable the processor again. The voltage at the lifted pins should be ~4.88 V. If it's significantly less (e. g. 2.7 V) the CPU might be damaged.
Interior fan working only on highest setting
The classical issue observed due to capacitor damage to the CCU. If the negative pin of C19 isn't connected to ground any more, it lifts the CPU pin pair 52/54 (CPU analog ground) and causes the processor pin 28 to stop providing a PWM signal for the fan control.
Display stays off, weak beep
If the processor is confirmed to be running (see below) but the display stays off and the confirmation beep is only faint (sometimes completely failing after the first press) the 5 V reference value for the sensor network should be checked. The reference voltage can be measured at pin 12 of the CPU (and others). It runs all around on the outside of the PCB's underside as well and is even found in the small green connector for the vehicle loom.
A too low voltage prevents the sensors from working as well as the beep indicator and the display.
A broken trace near Q9 can cause such a drop in the reference voltage:
Diagnostic - CPU Issues
A CCU with a non-working CPU won't show any signs of life. All display elements, LEDs, buttons and knobs are non-working. When plugged into the vehicle, no initialization motor movements can be recognized. One way to confirm a CPU problem is to check pin 30 of the CPU with an oscilloscope. That pin carries the clock signal and should show a 11.9 MHz wave of 3 V peak-to-peak:
If the CPU is unable to start, the following pattern can be observed. It repeats with a frequency of about 28.6 Hz and indicates the processor is stuck in a restart/reset-loop:
If the CPU refuses to start after capacitor removal, trace cleaning, trace repair and capacitor installation, it's might be damaged beyond repair. Installing the CPU on a known working CCU (using a 64 pin socket) is a proven way to confirm a broken CPU.
Updated 21-09-2025 at 03:24 PM by Heineken
Tags: None Add / Edit Tags
Categories
Technical Information
Comments
  1. Heineken's Avatar
    Added information on "Full Functionality but Display stays off"
  2. Heineken's Avatar
    Added information on diagnosing CPU issues
  3. Heineken's Avatar
    Added explanation why trace damage near C15 causes the fan control to stop working.
    Added explanation how trace damage near C14 causes the CPU to stop working.
  4. Heineken's Avatar
    Added information about a trace issue near Q9 that causes the 5 V sensor reference voltage to drop, affecting the display and the confirmation beep.
